Kyle Kraft
New User
Last spring I did some work on the tractor. I installed a new valve cover gasket after adjusting the valves per the manual"s procedure.
I rebuilt the carburetor (Carter UT) and installed a new throttle shaft, seals, gaskets, float needle. I adjusted the float level carefully to the specifications. I replaced the fuel line and sediment bowl. I replaced the short hose from the air cleaner to the carb.
When putting the carb back on the tractor, the governor rod would not go through the hole in the throttle shaft. The rod was 1/4" diameter so I grabbed a drill to open it up to 17/64" but the drill index at home is laid out differently than my index at work. I grabbed the wrong drill and opened the hole up to 9/32". Now the tractor surges badly at startup and also when placed under a sudden heavy load when mowing. It will also surge when the throttle is opened up quickly...something that it never did before.
Do a youtube search for farmall c mowing and watch the beginnin where I start it up.
I"m thinking a new throttle shaft is in the works with a much more closely sized hole for the governor rod.
What say you?
Untitled URL Link
What say you?
Untitled URL Link
