Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Putting a 6bt 12 valve cummins in IH350?
[Return to Forum]
Jonnymac348
10-11-2012 04:29:15
68.9.29.13
I was wondering to pick anyones brain I am looking into putting a 6bt 12 valve cummins into a International 350 tractor. I know you can buy or make the adapter plate and have to change the fly wheel. Was wondering if anyone knew what would need to happen with the front end mounting to the cummins. Assuming you would have to make new mounts. and was wondering if the front end would mount back again on the stock spot behind the oil pan where the pivot ball is with no modification or what would need to be done. what kinda flywheel should i use or buy.
Any and all help would be much appreciated.
Jon
[Reply]   [No Email]
uncle henry
10-11-2012 07:18:20
67.223.201.52
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to Jonnymac348, 10-11-2012 04:29:15
get a ups or a fed-ex engine they have four cylinder cummins in them
[Reply]  [No Email]
Jonnymac348
10-11-2012 07:44:11
68.9.29.13
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to uncle henry, 10-11-2012 07:18:20
thanks rick and i deff will take all that into consideration. deff use the tractor for more show then using it. Just think it would be cool and be really nice to do it. would deff be different. you wouldnt happen to know what the rear internals are estimated/ rated for hp wise.
Uncle henry thanks i will deffinatly start looking in that direction for a motor. They sell an adapter plate on ebay with a different fly wheel to make this work supposedly you know anything about that and whats needed for a clutch or what i can i use for a clutch. Leaman tractor parts offers it the adapter.
[Reply]  [No Email]
uncle henry
10-11-2012 08:14:25
67.223.201.52
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to Jonnymac348, 10-11-2012 07:44:11
one of our local ups drivers put over 1 million miles on his truck sorry i can't be of more help
[Reply]  [No Email]
oldtanker
10-11-2012 07:04:31
66.228.255.239
If you are making something for a show piece then fine, overcome the problems and drive on......but if you are thinking of a working tractor you will find that the rear part is going to be the weak link. That's way too much engine for that. Tranny input shaft, gears, final (ring and pinon) and axles will all become sheer "bolts".
Rick
[Reply]  [No Email]
DeltaRed
10-11-2012 06:20:59
67.6.219.50
With enough time and money ANYTHING is possible....Good luck and have fun with it.Share pics of 'journey and destination'Steve
[Reply]  [No Email]
D Slater
10-11-2012 05:55:56
184.15.8.46
Nice job on a 4 cylinder in a farmall 300. Don't know the details but a utility would be a lot harder to do.
[Reply]  [No Email]
Jonnymac348
10-11-2012 06:10:17
68.9.29.13
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to D Slater, 10-11-2012 05:55:56
i love that amazing job who ever did it. I can build some rail for it tie them into the existing front end mounts and front weight bolts. Making notes make rails, extend tins, extend steering.
[Reply]  [No Email]
D Slater
10-11-2012 08:14:30
184.15.8.46
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to Jonnymac348, 10-11-2012 06:10:17
Tractor was at a red power roundup in Minnesota I think was the state.
[Reply]  [No Email]
bermuda ken
10-11-2012 05:50:15
50.50.17.146
WHY???????? The T/A and Trans drive shaft will now become your drive line shearbolt.
In reality, the engine would be worth more than the rest of the tractor.
[Reply]  [No Email]
The tractor vet
10-11-2012 07:33:40
75.24.0.62
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to bermuda ken, 10-11-2012 05:50:15
IF ya did not get carried away with going much over 75-85 Hp the drive line would hold up fine . But you start pushen that little 4 BT to 100- up Well then we might start seen SPARE PIECES AND PARTS.
[Reply]  [No Email]
Jonnymac348
10-11-2012 07:47:56
68.9.29.13
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to The tractor vet, 10-11-2012 07:33:40
i deff remember that thank you for the advise. this is the stuff i need to know it will help me allot.
[Reply]  [No Email]
Jonnymac348
10-11-2012 06:33:15
68.9.29.13
http://www.tractorshed.com/gallery/uptest/a85383_sml.jpg
http://www.tractorshed.com/gallery/uptest/a85384_sml.jpg
i dont know if i did this right but an 03 ram 2500 with a 24 valve cumins i built frame off.
[Reply]  [No Email]
Jonnymac348
10-11-2012 06:39:34
68.9.29.13
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to Jonnymac348, 10-11-2012 06:33:15
I would deff do it right why im shareing my photos just trying to bounce ideas off problems people may have run into when doing this project of trans planting a cummins 4 cly or 6cyl in a 350
[Reply]  [No Email]
Jonnymac348
10-11-2012 06:20:55
68.9.29.13
so ill upgrade the sheer bolt lol (drive shaft) the block/ motor internals are completely done who ever did all this perfect make shift motor work welded the block so it beyond repair and ruined the internals, bent the crank, rounded the cam, bent the rods list goes on and on even if i find another c-175 block, and internals+ rebuild and machining still might cost as much as a putting a cummins in it and the cummins is a better motor. I love impossible task to make something different from the norm and make it better this is what i do everyday. I could do it going in blind with a small concept but rather learn from someone else problems they might have encountered then my own if this is the route I go.
[Reply]  [No Email]
farmallboy15
10-11-2012 05:03:37
64.247.89.145
It will probably be way to long without extending the frame rails, sheet metal and steering wheel. A 4bt MIGHT fit in there...
[Reply]  [No Email]
Jonnymac348
10-11-2012 05:21:41
68.9.29.13
 Re: Putting a 6bt 12 valve cummins in IH350? in reply to farmallboy15, 10-11-2012 05:03:37
this is a utility it doesn't have any rails forgot to put that part in. but that is true about the tins and steering good call. i think i could make the tins work though by extending them with new steel with my english wheel and re rib the panels with my bead roller.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
