| Farmall & IHC Tractors Discussion Forum |
Topic: 1953 Farmall Super H
[Return to Forum]
| Author |
[Modern View]
| Paul in SC
10-10-2012 18:11:10
166.248.78.58
I have a whine in transmission. All new bearings on driving shaft, sliding gear shaft and countershaft. Has been investigated enough to know it is not ring and pinion causing whine. Gear mesh and backlash on ring and pinion are set to existing specs. I suspect the constant mesh gear because all gears including reverse are noisy except fifth gear which of course is straight through. I know that changing bearings "tightens" things up and may cause different wear patterns. My question is do any of you with a SH have any problems with the constant mesh gear being noisy? Thanks, Paul |
[Reply] [No Email] | |
| Paul in SC
10-11-2012 17:49:22
166.248.79.81
Re: 1953 Farmall Super H in reply to Paul in SC, 10-10-2012 18:11:10
| Thank you all for your comments. Your advice and comments are most helpful. Paul |
| The tractor vet
10-10-2012 18:31:03
75.24.0.62
| Well If you changed the set on the ring and pinion to take up ware then you have found your problem . The set spec.'s are FOR NEW GEARS not ones that have gotten antiquated with each other over the years. |
| Janicholson
10-10-2012 19:41:18
96.24.99.126
Re: 1953 Farmall Super H in reply to The tractor vet, 10-10-2012 18:31:03
| With respect, the noise is absent in High gear. I would think the noise frequency/pitch would go up, but not be absent. If the pitch is the same in all gears at the same engine speed (possibly different loudness)that constant mesh seems a high probability. Jim |
| The tractor vet
10-11-2012 07:45:00
75.24.0.62
Re: 1953 Farmall Super H in reply to Janicholson, 10-10-2012 19:41:18
| Maybe , but tomany times guys think that oh wait a min. this ring gear needs to be tightened up and they start messen with pinion depth and resetting back lash on and old gearset . And you end up with a noisy ring and pinion . always check the old back lash first and with heavy grease check where the pinion sets in the ring gear for a pattern when you start changing bearings and keep all th3e org. shims on the same side as they came from. Just because the book says .009 -.0012-14 is what it should be NEW this is not going to be the case with OLD on new bearings . so if it had .025 on back lash on the OLD and on the new it ends up at .018 leave the back lash alone .and check the pinion pattern with heavy grease if ya don't have a red or white lead . Don't ask how i how this. |
| Janicholson
10-11-2012 08:16:16
199.17.55.139
Re: 1953 Farmall Super H in reply to The tractor vet, 10-11-2012 07:45:00
| I don't need to ask, been there. Jim |
| Janicholson
10-10-2012 18:28:11
96.24.99.126
| They do make some whine. Straight cut gears cannot be made noiseless, or they would be used in thousands of additional applications. Helical gears are far more quiet, but have slightly reduced strength, and dramatic thrust loading. Since you have refit the bearings, your choices are three: ignore it, Replace the constant mesh gears, or try to quiet it somewhat with 85 120 wt gear oil. I use synthetic 85 120 in several transmissions with 30% reduction in noise. Jim |
| John B.
10-12-2012 06:00:54
38.114.64.214
Re: 1953 Farmall Super H in reply to Janicholson, 10-10-2012 18:28:11
| I have to correct you on helical gears having reduced strength. These (helical) gears are stronger because they have more than one tooth in contact with the other gear at all times. |
| Janicholson
10-12-2012 14:21:56
96.24.99.126
Re: 1953 Farmall Super H in reply to John B., 10-12-2012 06:00:54
| They do have multi tooth contact it is just not the whole tooth. I stand unconvinced. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
