| Farmall & IHC Tractors Discussion Forum |
Topic: 450 1/8 copper oil-pressure tube...
[Return to Forum]
| Author |
[Modern View]
| P and R Pete
10-08-2012 13:24:47
173.86.14.68
...is leaking just behind the gas tank and dripping down, and here my FIL thought it was a hydraulic fluid leak. Got a new line, and am about to put it in, but a maybe/maybe-not dumb question- does the line need to be primed with oil? I sure hope not, which would make this 98% easier, but don"t want to miss a step. |
[Reply] [No Email] | |
| Dean Olson
10-09-2012 14:33:36
98.196.66.64
Re: 450 1/8 copper oil-pressure tube... in reply to P and R Pete, 10-08-2012 13:24:47
| | No need to prime. Go with a steel line. The PO of my 53 SH used a plastic line, it broke and his son ran it till it seized up. My 54 SH had a copper line. It broke when I was operating. I heard the change in the tone of the motor, looked down to see "0" oil pressure and immediately shut it down. Replaced with a steel line, refilled with oil, and so far have no apparent damage. |
| P and R Pete
10-09-2012 15:45:36
173.86.14.68
Re: 450 1/8 copper oil-pressure tube... in reply to Dean Olson, 10-09-2012 14:33:36
| | Too late. Got the copper line on today, fired it up, (the gauge works great, unprimed), and drove it to my FIL"s and back so he could see I"m making progress. I still have to make carb adjustments, since the carb was rebuilt by IH, and they set it up just to get it running. Got to adjust the governor too. The engine remains at idle for 2/5 of the movement of the throttle. |
| Harold H
10-09-2012 08:59:16
12.23.230.67
| | One suggestion, when replacing lines, use a steel brake line rather than copper tubing for oil pressure line or fuel lines. The copper will eventually harden and break whereas the steel line will last verturally forever. Harold H |
| mkirsch
10-09-2012 05:11:17
64.80.110.75
| Quoting Removed, click Modern View to see
Yeah, but it's amazing how much SMOKE it makes when dripping on a hot manifold!!! |
| Owen Aaland
10-08-2012 20:56:54
216.47.35.211
Re: 450 1/8 copper oil-pressure tube... in reply to Danny Hogge, 10-08-2012 13:24:47
I'm in the camp of just having air in the line, not full of oil. If you are in cold climates the oil can be thick enough that the gauge will be very slow to respond if the line is filled with oil. The older tractors with larger lines don't have the same problem nearly as much. |
| pete 23
10-08-2012 18:20:58
74.32.238.2
| I always leave the end off at the gauge, start engine and run until oil come out of pipe, shut down and hook it up to gauge. Some seem to feel you should let the line be filled with air but I feel you get a quicker oil pressure reading with the line full of clean fresh oil. It is amazing how little oil will actually flow through that little pipe. |
| P and R Pete
10-08-2012 19:38:14
173.86.14.68
Re: 450 1/8 copper oil-pressure tube... in reply to pete 23, 10-08-2012 18:20:58
| | What surprised me is that after I wrote my first question, I disconnected it slowly at the engine block, just wanting to see if oil was going to ooze from the block, finally being able to take it off altogether with no leakage at all, either from the block OR the tube. The oil that had made it up the tube to cause the leakage at the hole had all drained back down into the block. If that is always true, there is no need to prime. If it drained because of the hole providing an air leak, then maybe it does. I'll decide tomorrow when I'm doing it, I guess. The gauge-panel has to be off to connect to the gauge, but if the battery's connected in order to turn over the engine, I'll be risking short-circuits with the wires being 'live'. Maybe the gauge alone can be extended from the gauge-panel. Daylight will tell. Right now, I have to get back to my still-warm-from-the-oven peach pie. Thanks for your thoughts! |
| Phil Tibbetts
10-08-2012 14:19:44
208.93.14.38
| No need to prime it |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
