Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: positive to negitive ground
[Return to Forum]
hrtuffenuff
10-06-2012 18:31:26
68.33.200.109
can i change a 12 volt positive ground system to negitive ground by changing voltage regulator.
Or does gen. need to be changed internally?
[Reply]   [No Email]
John T
10-07-2012 08:26:48
216.249.82.117
 Re: positive to negitive ground in reply to hrtuffenuff, 10-06-2012 18:31:26
As noted and first of all, the genny can charge at either Pos or Neg Ground and of course, you need to Polarize the genny BEFORE start up. Some VR's are labeled as suitable for use at Pos or Neg ground, so you might wanna check that. If its a batery powered coil distributor ignition and you change battery polarity the coil leads need swapped also as well as the ammeter leads (if it has one) or it would read bass ackwards.
John T
[Reply]  [No Email]
mkirsch
10-07-2012 07:27:48
67.253.161.186
On a generator/regulator setup, you only need to do three things to swap ground:
1. Switch the cables on the battery.
2. Switch the cables on the ammeter.
3. Polarize the generator.
Please note you can NOT do this to an alternator system.
[Reply]  [No Email]
wisbaker
10-06-2012 19:52:17
207.118.177.28
If it's a gasser (spark ignition) you should also change the coil polarity & the leads on the ammeter.
[Reply]  [No Email]
pete 23
10-06-2012 18:44:35
74.32.238.2
A generator does not care which way it is grounded, neg or pos. Some voltage regulators do but most you buy now days work with either ground. Ordinarily a regulator is marked if it is polarity sensitive, on the under side or on mount somewhere saying which ground it is. At any rate, you need to polarize it to the ground system you are using. Momentarily , with everything hooked up but before you start engine, flash the generator terminal to the battery terminal. Just use any kind of a jumper wire to touch them terminals so you get a spark and that will turn those little electrons so their north and south poles are pointing in the right direction.
[Reply]  [No Email]
Nebraska Kirk
10-06-2012 18:38:39
207.91.4.159
You do not need to change anything in the generator, but after changing to negative ground, you will need to repolarize the generator.
[Reply]  [No Email]
gene bender
10-06-2012 18:35:05
67.55.227.68
polarize the gen
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
