Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: diesel tractor not running good UPDATE
[Return to Forum]
john in pennsylvania
10-06-2012 09:49:42
70.194.9.47
First of all thank you everyone for their input I really appreciate all the help. Here is the situation currently. It was actually a little hard to start this morning not like normal. I removed the air hose on the intake manifold so there's no restrictions it feels to be drawing in nicely. I remove the valve cover started the engine. All valves seem to be working fine moving freely and plenty of oil pumping. I cracked all the lines to each injector one at a time. The RPM dropped on every injector allowed to leak fuel. It seems too be idling smooth and up to 1200 RPM runs smooth. There's very little smoke at idle but when you open the throttle wide it's coal black. For anyone new looking at this post it's an international 364 diesel tractor. With a Bd 154 engine and a CAV injection pump. Only 1200 hours on the hour meter.
[Reply]   [No Email]
oldtanker
10-06-2012 10:41:16
66.228.255.239
Re: diesel tractor not running good UPDATE in reply to john in pennsylvania, 10-06-2012 09:49:42
The black smoke indicates one of several things.
1. Air restriction giving a rich fuel air mixture.
2. Pump/injector problem, feeding too much fuel, making a rich fuel air mixture.
3. Engine problem giving a poor burn. Low compression, bad timing ECT.
So from what you have done so far, check valve clearances seeing as how the cover is off. Then check injector timing by the book. Check and make sure the fuel return line isn't plugged. That can cause the pump to make to much pressure and cause a rich fuel mix problem.
Once al of that is done if you still have a problem it amy be time to pull the pump and injectors and have them tested. Doing a compression test would be in order too.
Rick
  [Reply]  [No Email]
10-06-2012 11:00:32
70.194.9.47
Re: diesel tractor not running good UPDATE in reply to oldtanker, 10-06-2012 10:41:16
I will check the timing and valves
  [Reply]  [No Email]
jimb2
10-06-2012 10:35:13
99.241.38.122
Hi John, run it up to where it is smoking badly and pull the shut off lever out a little and see if the smoke stops?
I have a Perkins Diesel engine trouble shooting guide and a DPA CAV rotary injection pump test instructions guide in pdf format.
If you email at clarabrownlee@rogers.com, I can email them to you.
JimB
  [Reply]  [No Email]
10-06-2012 11:08:29
70.194.9.47
Re: diesel tractor not running good UPDATE in reply to jimb2, 10-06-2012 10:35:13
Tried to email you....did not go. My email is jwmirz@aol.com
  [Reply]  [No Email]
jimb2
10-06-2012 12:50:13
99.241.38.122
Re: diesel tractor not running good UPDATE in reply to john in pennsylvania, 10-06-2012 11:08:29
Hi John,
I got delayed but emailed the two pdf docs to you about 20 minutes ago.
JimB
  [Reply]  [No Email]
10-06-2012 10:59:27
70.194.9.47
When i rev it up....black smoke until it reaches its RPM. The the smoke is vert little. If i pull the shut off part way out i have no throttle response. I will email you....thanks
  [Reply]  [No Email]
carogator
10-06-2012 10:27:25
205.188.117.74
You moght want to check that your tank vent is open and not plugged.
  [Reply]  [No Email]
10-06-2012 09:50:51
70.194.9.47
Forgot to mention I'm in the shop right now so if there is something you want me to check or try please let me know
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
