Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 560 problem
[Return to Forum]
brandon56
10-03-2012 15:40:33
108.84.33.181
I have a 560 gas that is driving me nuts. This tractor will not start all the time. Its very erratic and sometimes I will shut it off and come back to it 20 minutes later and it won't start. I rewired it last spring and installed a pertronix kit with a new coil and it ran great all summer. Any idea as to what it could be? I can't seem to pinpoint why it sometimes doesn't start.
[Reply]   [No Email]
rhtx55
10-03-2012 17:22:38
207.119.54.109
 Re: 560 problem in reply to brandon56, 10-03-2012 15:40:33
Sounds like the coil is going bad, try a replacement for "testing" purposes.
If the new coil makes no difference check the voltage at the battery first, then the coil while cranking the engine ( coil wire removed) could be the starter is pulling too many amps and not enough left over to supply the coil.
Bad ground at the battery, frame, starter or cable ends corroded will also cause this problem.
The little "solenoid" on top of the starter may need a good ground contact ( bolts that hold it to the starter) or possibly replaced.
Just guessing here, but these are some of the problems I have found that drove me nuts.
[Reply]  [No Email]
Janicholson
10-03-2012 16:43:17
96.24.99.126
Diagnostic First step. Does it have spark when not starting. Check voltage at the coil input when it won't start. (leave the key on) if voltage, check for coil spark to block. Spark good go to fuel.
Gas on fuel in carb?
No crank is a different issue, we need to know what it is not doing. Jim
[Reply]  [No Email]
Dennis 1957
10-03-2012 16:27:36
68.65.103.37
Like tractor Vet said throw fancy stuf in junk go back to points a lot less trouble.
[Reply]  [No Email]
The tractor vet
10-03-2012 16:05:57
75.24.0.62
Throw the fancy ing. away and go back to the points . Just about each and every one that i put in years back failed including the one i installed in our one pulling tractor . Really look bad when ya are the one setting in the seat in front of all your customers making a bonzi run for the gate at twice the speed of the best out there and have it fail and have the sled hit you so hard that it shoves ya fifteen more feet . Yea i won the class but that was not the statement that i was tryen to make on that pull. Had to get drug back to the pit and i swapped out that piece of junk for old fashioned Points and cond. and let my buddy make the statement of the true meaning of out the gate and half way around the 1/2 mile track then shut it down . OLD fashioned points can be filed rest set with a match book and get you home , not with this high tech junk. where she dies is where she sets .
[Reply]  [No Email]
oldtanker
10-03-2012 16:12:30
66.228.255.239
 Re: 560 problem in reply to The tractor vet, 10-03-2012 16:05:57
HMMMMM I'm running IE with no problems.
Rick
[Reply]  [No Email]
oldtanker
10-03-2012 15:50:39
66.228.255.239
First, if it's a no start check and make sure you have spark. Needs to be bright blue and jump 1/8-1/4 inch. The further the better. If no spark trouble shoot the ignition system. First is to make sure the switch is good. Turn it on and check voltage to the coil. Turn off and on and repeat test each time 4-5 times. Next check to see if you have pulsing voltage to the distributer side of the coil while it's being cranked. If not you may have a wire that is sometimes grounding going into the dizzy or there is a problem with the IE.
If you do have spark check for fuel to the carb. Don't know on the 560 but a lot of old good carbs have a drian plug in the bottom od the bowl. Pull the plug with a clean coffee can under it. Should have a steady stream of gas running out, keep it running like that for a minute or 2. That allows the what gas is in the bowl to drain. If it turns into a dribble then you have a blockage to the carb. If it flows good then the problem is in the carb.
Rick
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
