Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Blown head gasket on A
[Return to Forum]
Mr Farmall
10-03-2012 14:27:28
174.57.6.117
Four years back my A started to pump out white smoke, sure enough it was a bad head gasket. Found antifreeze in the crankcase. Replaced the head gasket with an IH/Case gasket. Cleaned off the deck and head real well. I used Permatex copper spray a gasket on the new head gasket, torqued the head to 65 ft/Lb like the repair manual states.
Now the A has started smoking white really bad again, I can't find antifreeze in the oil and the compression checks out okay. It has never overheated as long as I have owned it, don't know if it ever did before I bought it.
Any suggestions to ensure that the next head gasket last longer? Should I have the head checked and milled if needed?
[Reply]   [No Email]
gene bender
10-03-2012 17:42:48
67.55.227.68
Re: Blown head gasket on A in reply to Mr Farmall, 10-03-2012 14:27:28
Head should be 80lbs and your smoke could be coming from residue in the muffler running it under some load should burn it out but i would retourque the head.
  [Reply]  [No Email]
charlie M
10-03-2012 16:58:26
74.34.216.81
Maybe a cracked sleeve? When I bought my A last fall the previous owner had to replace 2 sleeves because they were cracked. They are wet sleeves.
  [Reply]  [No Email]
ken house
10-03-2012 15:22:33
173.242.240.50
without a doubt, have head checked. it is your machine and not mine, but, i believe that i would run the motor, get it warm and torque the bolts up to the new specification.
  [Reply]  [No Email]
old
10-03-2012 14:36:50
209.86.226.61
The new torque for that is 85ft/lbs so that in it self may help. When I built my BA I used a used head gasket metal one and 6 colts of aluminum paint and it has been just fine. I too did use the 65ft/lbs but since it has not leaked I have left it alone but did re-torque it after I had warmed the engine up
  [Reply]  [No Email]
Mr Farmall
10-03-2012 16:05:47
174.57.6.117
Re: Blown head gasket on A in reply to old, 10-03-2012 14:36:50
I have tried tighting it up to 85 torque, it didn't help. Still smokes white really bad.
  [Reply]  [No Email]
old
10-03-2012 17:05:08
209.86.226.32
Re: Blown head gasket on A in reply to Mr Farmall, 10-03-2012 16:05:47
Yep either you blew the head gasket again which happens or you may have a cracked head which would be bad
  [Reply]  [No Email]
Mr Farmall
10-03-2012 22:43:28
174.57.6.117
Re: Blown head gasket on A in reply to old, 10-03-2012 17:05:08
Just found an online article that says copper spray a gasket attacks the coating on metal head gaskets. That is probably what happrned with my A. I will have the head milled just to be sure.
  [Reply]  [No Email]
old
10-04-2012 07:46:58
209.86.226.19
Re: Blown head gasket on A in reply to Mr Farmall, 10-03-2012 22:43:28
Also when you put it back on use a coat of aluminum paint on both sides of the gasket install that tacky. Torque the head down wait say an hour then start and after warm re-torque the head
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
