Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: leaky float
[Return to Forum]
charlie M
10-01-2012 16:48:23
74.34.216.81
I've got a float that has liquid inside. I tried putting it in hot water to find the leak but no luck.I'd like to try fixing it before junking it. Its off a 30 year old snowblower so I don't even know if a new one is available.
[Reply]   [No Email]
Heat Houser
10-01-2012 19:03:49
69.66.35.73
 Re: leaky float in reply to charlie M, 10-01-2012 16:48:23
Repaired the float on my 560 Farmall. There is a small vent hole as noted below. I used a hair dryer to warm up the float, rolled it around to see where the "wet" spot was. Marked it, opened the vent hole, finished draining the gas, used a heat gun to "preheat" the float, and soldered the area of the leak. Maintained the "preheat" so I could solder the vent hole shut so expanding air wouldn't blow out the solder.
Clean and shiney brass is good...LOL
[Reply]  [No Email]
rusty wheel
10-01-2012 18:29:44
75.180.23.218
I have used s magnifying glass to find the leak. Then open it up just enough to let the fuel leak out. When it's dry clean the spot with steel woool and solder it closed. Remove any excess solder with a small file. Then submerse it in a can of fuel and hold it down with a weight overnight. Check it the next day to see if it has fluid in it. If it doesn't,you're good to go. I have done this several times with great success. RR
[Reply]  [No Email]
teddy52food
10-01-2012 17:50:54
184.94.175.179
Look for a small spec of solder away from the seam. Heat it with a soldering iron & open the hole with a pointed toothpick. Drain the gas out & resolder. Then put it in boiling hot water to find the leak. Solder the leak after opening the vent. After it is cool, close the vent & test again. Try not to add too much solder or it may get heavy.
[Reply]  [No Email]
John G. Hasler
10-01-2012 17:29:57
72.160.238.118
Punch a hole in it and drain the liquid out. Plug that hole with JBWeld and put JBWeld on all the suspicious spots (those will be solder joints). Don"t apply a lot of JBWeld as that would make the float too heavy. That"ll hold it for a while, but as rustred says, the only real solution is to replace it. Floats can be resoldered, but doing so is a real PITA.
[Reply]  [No Email]
rustred
10-01-2012 17:04:27
72.172.100.113
if it has fluid in it then its toast,unless your a real perfectionist at fixing stuff. just get the engine model and make and and carb #. i am sure there is new ones out there.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
