Charlynn pto hydraulic pump mount
mkirsch
I picked up one of those char-lynn power pack PTO pumps off craigslist here a couple weeks ago.
Ready to mount it. Anybody have a picture of how they mount on a Farmall A? I need to fabricate up a bracket.
If you are going to run it on the pto you will need a Lovejoy coupling or one similar. You are also going to need a bracket mounting the pump to the PTO assy. Or you can move the pump sideways and run it with a roller chein either way you will need to make the brackets to mount it some do run them off the belt pulley but you will need to fix it so the pump doesent turn over 750 RPMs I use two of them both on Bs. I did make a mount to run on on an A customer wanted it that way. Those are great units 10 gal per minute @1000 psi. You can still get parts for them.
Right, I need to know what the bracket looks like, and where it bolts on the tractor in order to fabricate one up myself.
It came with a homemade bracket for something. Whatever it was, it was connected directly to the PTO with a double-roller-chain coupler.
Heh, what I'd really like to do with it is put it on a W4 or W6. I just need to buy a W4 or W6.
