Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Add on 3 Point Hitch
[Return to Forum]
Fullers Farmalls
09-30-2012 23:07:40
24.239.77.45
I found an add on 3 point hitch for a Farmall. I'd plan on putting it
on my H or Super M or getting a third tractor for it. It doesn't have
a model but looks like the Saginaw but only has one cylinder. The
arms aren't perfectly straight, the cylinder doesn't look perfect but
is plumbed for 2-way hydraulics. It's about 2 hours away, but
pretty cheap. Is it worth it? I don't have pics but I am pretty sure
it'd fit. Thanks
[Reply]   [No Email]
DeltaRed
10-01-2012 07:25:51
67.6.219.50
 Re: Add on 3 Point Hitch in reply to Fullers Farmalls, 09-30-2012 23:07:40
I would go for it.A single cylinder is just finr if you dont plan on carrying a heavy planter ,big sprayer.or heavyplow.For bladeing,brushhogging,other 'light' jobs-no problem.You seem to be a real 'handy' guy,if it needs a little tweaking,I;m sure you can easily fix it.The biggest problem with theos single cyl 3 points is the 2"rockshaft is too small,it twists easily.BTW,On my shopmade 3 point,the rockshaft is 2 1/2" square(the ends are machined round to accept a bushing).My SM 3pt only has one cylinder,will lift more than the frontend will hold down with a 3 1/2" cyl..The mag pump puts out 1200psi.Good luck and enjoy your 'new, 3 point!
[Reply]  [No Email]
mkirsch
10-01-2012 05:17:38
64.80.110.74
If you don't plan on doing any heavy lifting or abusive work with it, one cylinder is fine.
A second cylinder can usually be added pretty easily by someone with some basic fabrication skills if you really feel it is necessary.
What kind of work do you envision for this 3pt? That will tell you if it's worth it or not.
This is worth exactly what you paid for it, but IMHO the add-on hitches do not work well for moldboard plowing. Mostly because they don't have draft control, which makes keeping the plow at a consistent depth a manual process. Tough to do a good job of plowing.
[Reply]  [No Email]
Fullers Farmalls
10-01-2012 08:27:21
158.83.130.31
 Re: Add on 3 Point Hitch in reply to mkirsch, 10-01-2012 05:17:38
Don't plan on plowing. Mainly back blading, landscape raking and
what ever other fun 3 point hitch attachments I come across.
Thanks guys!
[Reply]  [No Email]
DeltaRed
10-01-2012 07:03:52
67.6.219.50
I have plowed quite a bit with a 2 bottom and 3
bottom mounted rollover plow on a Super M.I simply
put stop collars on the cylinder.holds the plow at a
consistant depht all day...The 'ole super' just
"walked the dog".Another benefit is you dont have
wheel slippage or need to add wts.'Suction' and the
weight of the plow takes care of all that.
[Reply]  [No Email]
Zachary Hoyt
10-01-2012 03:46:47
184.8.254.154
I have a dual cylinder hitch on the H and it has been handy while I've had it, which has only been a few months. I'm selling the H now that the 300 is in working order and I'd be happy to sell the hitch off it separately since I still have the drawbar to put back on.
Zach
[Reply]  [No Email]
Dave_Id
10-01-2012 04:53:14
75.92.58.173
 Re: Add on 3 Point Hitch in reply to Zachary Hoyt, 10-01-2012 03:46:47
The Saginaw hitch mfg'd for the Super C has one cylinder.
[Reply]  [No Email]
mike1972chev
10-01-2012 03:22:58
75.149.81.173
If I were getting a 3 point,I would be looking for a DUAL cylinder one.
[Reply]  [No Email]
FBH44
10-01-2012 00:55:47
64.85.217.8
My 3-point was a weak one, and afteryears of heavy use and plowing and lifting and etc., the cylinder-arm (left one) was higher than the right non-cylinder one. The center round-bar had twisted a bit, and the right-hand arm had bent down a little bit. Had to have it rebuilt, and that was pricey. HOWEVER, a 3-point will absolutely be worth it. Makes a Farmall into a real work tractor.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
