Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 350U distributor timing mark
[Return to Forum]
linemechanic1
09-30-2012 18:09:46
69.86.135.178
This message is a reply to an archived post by Janicholson on April 08, 2012 at 13:28:21.
The original subject was "Re: Farmall 300 Timing Marks".
I always thought that the first mark on the damper which passed under the pointer indicated some degrees BEFORE TDC. My 350U has 4 marks. I used the 1st to set valve lash and eyeballed the #1 on the cap so I"m sure I could have been off some. It did start within a couple of seconds (after new rings, valves, rod bearings, etc), so I couldn"t be TOO far off. Should I use a timing light? And which mark should I go for?
[Reply]   [No Email]
CNKS
09-30-2012 18:38:03
216.144.104.128
Re: 350U distributor timing mark in reply to linemechanic1, 09-30-2012 18:09:46
My Operators manual says the mark by itself is TDC, the next is 16 degrees, the book doesn't specify what that is, the next is 22 degrees (at full 1925 rpm) for a gas or kerosene engine, the last is 30 degrees for a distillate engine, so apparantly the only two to be concerned with the TDC and 22, which is determined with a timing light.
  [Reply]  [No Email]
CNKS
10-01-2012 06:58:48
216.144.104.128
Re: 350U distributor timing mark in reply to CNKS, 09-30-2012 18:38:03
The rpm I gave is for a 350 row crop, I don't have the data for a 350U -- the max rpm may be higher for the utility, but the marks will be the same, likely the 22 degrees is the same also, but may be at a higher rpm?
  [Reply]  [No Email]
Janicholson
09-30-2012 18:23:39
96.24.99.126
You are correct. The last mark is TDC. I am at times rotationally dislexic. Jim
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
