Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: gerator oil pump on 1066
[Return to Forum]
redjohn
09-30-2012 10:46:51
74.33.71.44
First I want to thank the people who responded to my priming a diesel question.
I made sure there was fuel in both fuel filters, and it ran down to the injector.
I cracked the injector lines, then decided to crank the motor over, instead of pumping on the injector.
While cranking, I watched the oil pressure gauge. The gauge pressure never came up.
For those of you who didn't read my other listing, this tractor was in a fire, so the motor (1466 motor) was rebuilt. I rewired the tractor, with a wiring harness kit, and re painted the tractor.
My question is, what does it take, or what should have been done with the gerator oil pump, as far as if it needed priming befor installing in motor, or what.
I'm pretty good with a wrench, and have done alot of overhauls, just not diesels. I had a very good book on the rebuild. It was the IHC service manual for 3 and 400 series diesel engines.
I'm nervous about cranking the motor over with no oil pressure and having it start.
Before you ask, yes there is oil in the crankcase.
Just checked the book, and am wondering if the pressure regulator may be bad, possible melting from the fire?
I'm open to suggestions
[Reply]   [No Email]
Owen Aaland
09-30-2012 23:01:49
216.47.35.126
 Re: gerator oil pump on 1066 in reply to redjohn, 09-30-2012 10:46:51
There is a lot of oil galley area fill before you will see any oil pressure. Filling the oil filters before installing them helps but you still have the oil cooler and all the block galleys to fill. The best is to pressure bleed the oil system before you start. I usually install 2 - 3 gallons through my pressure bleeder before cranking the engine.
[Reply]  [No Email]
buzzinduzzin
09-30-2012 17:40:42
66.220.92.37
sometimes with that style of pump it takes more than cranking r.p.m. to get the pump going
[Reply]  [No Email]
Janicholson
09-30-2012 13:25:17
96.24.99.126
Filling the system with oil can be done easily with a pump oil can. Use a bit of vinyl hose, or rubber to make a connection from the spout to the oil pressure sending threads in the block. Put engine oil in the can, and pump till it feels like you have more difficulty pumping. (it might take 3 cans of oil or many more if the filter is not full). this primes the system and assures at least a high probability of pressure. Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
