Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 574 Hydraulic troubles
[Return to Forum]
mad_hacker
09-30-2012 09:10:53
68.171.231.84
Hi. My 574 has developed some hydraulic troubles. No power steering, three point is stuck in the raised position, and no flow/pressure to the scv's. Also the pump sounds like it is under load all the time even when there is no demand. I just changed the fuid and filter to see if that would help, but it didn't make any difference. Anyone have any ideas?
[Reply]   [No Email]
jimb2
09-30-2012 10:13:56
99.241.38.122
Hi Mad, was there and hydraulic oil in the filter
housing when you changed the filter? Does the 574
have remote hydraulic outlets? Make sure the
remote control valve has returned to the center
off position. So 3pt will not go down even with
engine off? The hydraulic system is an open center
system, which means in the idle condition (no
control valves being activated) the hydraulic oil
is always circulating. For 3pt and draft control
and remotes, the high pressure line is lower right
line on MCV behind the filter, the return is the
line above the high pressure line.
From Bernard le Mecano,3 pt will not go down:
There is a cover on the right side under the seat
in front of the rock-shaft. Remove and check if
the spool valve moves with the position lever.
Make sure the draft control lever is down. It has
a long spring, with a rod, maybe the spring is
unhooked.
Hi, maybe the unload valve is stuck. Check with
engine running, raise the hitch and at the same
time pull the remote hydraulic lever. If the hitch
raises, there is dirt in the unload valve. This
valve is under the seat and you have to remove the
large plug for access. One trick, loosen the large
plug, unload valve about 2 turns and start the
engine, the 3pt hitch should raise if the valve is
stuck. It has a small hole in the valve and just
blow the dirt out with air. Replace with new O
rings.
Hope this helps
JimB
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
