Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: F-20 Engine rebuild questions
[Return to Forum]
Evan From IA
09-30-2012 08:47:18
207.199.214.173
The motor only has the crankshaft in it now, and I was wondering if the crankshaft roller bearings need replacing or not. When rolled over, the bearings do make some noise(a hum or a light growl) , but I don't beleive it is a bad noise and the balls in the bearings aren't pitted or cracked. Should I replace them with a good used set or leave them in and start the rebuild?
My other question is about the reuse of the rod cap bearings. I understand that these can have wear, but when I re-install them I need to remove or add shims according to the plastigauge measurement. Am I right?
Any help would be appreciated. I'm restoring this F-20 for my 4-H club.
[Reply]   [No Email]
SDE
10-01-2012 05:44:11
174.124.53.135
 Re: F-20 Engine rebuild questions in reply to Evan From IA, 09-30-2012 08:47:18
Rod cap bearings.
Use a magic marker or blue die and coat the bearing surface. Install them with enough shims removed that they are making contact with the crank journal. Rotate the crank enough for the contact areas to appear in the rod cap. Now you scrap material away from the contacted area and repeat the process until you have a bearing contact area that is close to being about 75% of the total bearing surface. Being a machinist, I made a shaft to fit the bearings onto before putting them in the enigine. I have only done this to one tractor and I still have not got it assembled enough to get it running. Check the archives for more info.
SDE
[Reply]  [No Email]
rustred
09-30-2012 22:23:32
72.172.100.113
when checking those brgs. , have you cleaned them good then oil them lightly then roll them over? any noticeable noise and replace them , but they may still out last you as they only run around 1000 rpm.
yes, you can reuse rod brgs. check and adjust with plastigage but stay on the maximum clearance end as they are already worn egg shaped.i check with plastige in three positions on crank.
[Reply]  [No Email]
F-Dean
09-30-2012 12:12:51
70.194.76.97
If the rod cap bearings don't show signs of uneven wear, use them. I use plasti-gauge at 0.005 inches. Be sure to remove the plasti-gauge and oil them (I us automatic transmission fluid from Walmart) when you put them on the final time.
Others may want them tighter but you will probably not be plowing with it so don't worry.
[Reply]  [No Email]
Nebraska Kirk
09-30-2012 11:48:00
207.91.4.159
I second what Old-F20 said, replace the main bearings with new. Don't pay $200 each for new old stock, look on ebay, I bought new bearings for my Farmall Regular for around $30 each off of ebay.
A quick lesson on the bearing numbers:
The original numbers are 1313 for the front and 1315 for the rear. These are the max-fill heavy-duty bearings with more balls than standard bearings. However, there is no reason why you cannot use the standard-duty bearing as the tractor will not be doing heavy field work all day every day like when it was new. The numbers for standard duty bearings are 6313 for the front and 6315 for the rear.
[Reply]  [No Email]
Evan from IA
09-30-2012 12:10:43
207.199.214.173
 Re: F-20 Engine rebuild questions in reply to Nebraska Kirk, 09-30-2012 11:48:00
Was the ebay seller's name irvineman? I found his roller bearings online for $30.
[Reply]  [No Email]
Old-F20
09-30-2012 11:36:52
71.7.101.5
you can go to a good bearing supplier and get the very reasonable. better yet you can find them on ebay for very cheap. i got a front F-30 bearing brand new in the package (NSK brand) for 35 bux. cant beat that
[Reply]  [No Email]
Old-F20
09-30-2012 10:23:49
71.7.101.5
if it's tore down that far do yourself a favor and replace them. growly bearings only get worse, they will never heal themselves
[Reply]  [No Email]
Evan from IA
09-30-2012 10:40:25
207.199.214.173
 Re: F-20 Engine rebuild questions in reply to Old-F20, 09-30-2012 10:23:49
Maybe I could buy a good set from Nebraska Cowman
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
