| Farmall & IHC Tractors Discussion Forum |
Topic: Wheel weights
[Return to Forum]
| Author |
[Modern View]
| Old weldor
09-27-2012 07:55:34
67.142.183.25
I know this has been posted before,but I could not find it. What size bolts are needed to put one set of rear wheel weights on my 300 farmall? Also any tips on installing them,1 piece weights would be appreciated.thanks in advance. |
| Yooper Farmall
10-01-2012 13:52:57
141.210.112.16
Re: Wheel weights in reply to Old weldor, 09-27-2012 07:55:34
| Re: Bolts for farmall h rear wheel weights in reply to TylerFarmallH, 05-07-2012 18:51:45 I put my wheel weights on Sunday afternoon, I put both weights on the land (left) side. The bolt specs were provided by FarmallHal, he got them from his Farmall IH Parts Catalog.For the first set bolted to the cast iron center: 3/4" x 4 3/4" NC machine bolts along with 3/4" lock washers and hex nuts. For the second weight that bolts to the first weight: 3/4" x 3 3/4" NC machine bolts along with lock washers and hex nuts. washers should be 1 1/4" OD x 25/32" ID 10 gauge. I ended up purchasing the bolts from fastenal.com, for the first set instead of 4 & 3/4 length I went with 5", for the second set instead of the 3 & 3/4" length I went with 4" first set: http://www.fastenal.com/web/products/detail.ex?sku=20373 Fastenal part no 20373 ¾-10 x 5” plain finish square head bolt $4.42 each second set: http://www.fastenal.com/web/products/detail.ex?sku=20369 Fastenal part no 20369 ¾-10 x4” plain finish square head bolt $3.65 each I got lock washers and hex nuts from tractor supply as well as 1 1/4" machine bushings that I put behind the lock washers. Each weight is 145 lbs, I lifted a weight to the cast iron center, lined up the holes and had my wife slip the top bolt in and finger tighten the nut. Then I was able to put in the other 3. I used the method of 1st weight to wheel center and 2nd weight to 1st weight because I was lifting them by hand, but another method is getting longer bolts and connecting both weights with the 4 bolts instead of 8. Good luck. |
| MisterT
09-28-2012 06:47:26
67.55.162.174
Re: Wheel weights in reply to The tractor vet, 09-27-2012 07:55:34
| Quoting Removed, click Modern View to see
I've put hex head bolts into the square holes and had no problems with the bolt spinning. |
| mazemeister
09-27-2012 17:09:37
24.187.98.163
| | the diameters is 3/4" not sure of length. original was square head to fit square countersunk holes in weights. i had hex head bolts, so just welded enough of a nub on one side so they would hold in the square hole. for putting it on the wheel- i like to hang the weight by its center hole on a forklift. save the back, ya know? |
| sflem849
09-27-2012 16:54:14
69.197.84.39
| It is actually in the parts manual. |
| Super-H-Mike
09-27-2012 09:26:27
76.164.144.30
| I used 3/4 X 4 inch grade 8 bolts, worked well. The originals had square heads, but hex worked just fine for me. |
| caterpillar guy
09-27-2012 08:03:34
68.188.235.228
| I would think about 4 inch bolts would be good. I would use some grade 5 threaded rod with nuts on both sides that way one bolt could be used as a guide then put the rest in afterward. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
