Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: farmall sm
[Return to Forum]
tom thorn
09-25-2012 15:34:25
50.49.224.246
what should the compresion be on a super m with a 450 gas head 4 1/4 bore
[Reply]   [No Email]
mkirsch
09-26-2012 06:02:48
64.80.110.74
 Re: farmall sm in reply to tom thorn, 09-25-2012 15:34:25
Compression in PSI as in a compression check, or compression RATIO?
In PSI, more is better and consistent across all cylinders is more desirable than a high compression.
IIRC you need 90PSI for an engine to run decent.
>100PSI is an engine with a lot of life left in it.
>125PSI is a good strong engine.
[Reply]  [No Email]
mike1972chev
09-26-2012 03:49:35
75.149.81.173
Like has been posted already. MANY factors affect compression.(Combustion chamber CC,piston dome/dish,cam timing,cam profile,ect.)
Probably MORE important is that all cylinder PSI readings are within a small percentage of each other.
[Reply]  [No Email]
Super-H-Mike
09-26-2012 08:46:51
76.164.144.30
 Re: farmall sm in reply to mike1972chev, 09-26-2012 03:49:35
That is true Mike72. On an old tractor engine a psi that is close to even on each cylinder is a good indicator of how healthy the engine is. But, the higher the cranking compression the more likely the engine will be powerful, which is what I think he is after. In automotive, a 350 Chevy will run fine with 90 psi even compression, but if you want a motor that builds big power you will want that number much higher. Cam timing and profile can change things drastically as you stated. I have a snortin 454 BBC here that has 185 psi cranking.
[Reply]  [No Email]
mike1972chev
09-26-2012 10:53:20
75.149.81.173
 Re: farmall sm in reply to Super-H-Mike, 09-26-2012 08:46:51
Me too. ;)
Thread is now "high jacked" lol
[Reply]  [No Email]
Super-H-Mike
09-26-2012 11:47:09
76.164.144.30
 Re: farmall sm in reply to mike1972chev, 09-26-2012 10:53:20
Yowza ! Put that in an SM, lol
[Reply]  [No Email]
robgIN
09-25-2012 17:01:56
76.208.51.131
unless you are running without sleeves you won't have a 4.25" bore, stock was 4.00, most are rebuilt with the overbore kit to 4.125". If you are looking for a psi that will depend on piston design, bore dia and combustion chamber cc. Put a compression guage on it and see what you have .
[Reply]  [No Email]
dblair
09-25-2012 16:12:08
67.172.201.147
298 cu in , 7.18 to 1 compression with flat top pistons .
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
