Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: H4 I/H Magneto
[Return to Forum]
Leonard Dacus
09-25-2012 11:04:14
199.68.231.217
Magneto on U2A power unit not firing. it is H4 I/H magneto,is there a way to check condensor with a multimeter to see if it is ok. unit was running, was going to shut down accidently touched hot wire from battery to screw on side of megneto has not run since.any help would be appreciated.
[Reply]   [No Email]
El Toro
09-26-2012 03:49:24
108.3.143.30
 Re: H4 I/H Magneto in reply to Leonard Dacus, 09-25-2012 11:04:14
I would replace the condenser. Touch those magnets with a flatblade screwdriver to see if they will attract that screwdriver with a lot of effort. If they appear to be ok and there's no fire with the new condenser you probably fried the coil. Hal
[Reply]  [No Email]
Bob M
09-25-2012 11:35:47
74.67.191.50
Several possibilities caused by an accidental contact with the battery:
1 - Breaker point contacts got burned. Try dressing with a point file then resetting the point gap to 0.013.
2 - Coil primary has been fried. Check with an ohmmeter: A good coil will show a few tenths of an ohm between the breaker points insulated contact and ground with the points open. If the meter shows open circuit it's time for a new coil.
3 - The magneto magnet became demagnetized. Repair is best left to a good magneto rebuilder.
As for testing a condenser, disconnect the wire from the condenser to the breaker points. Now take you ohmmeter, set it to it's highest scale then take a reading between the condenser's lead and case. A good condenser should initially show relatively low resistance which gradually increases over several seconds to several megohms.
If the meter shows infinite resistance (open) or 0 ohms (short circuit) the condenser is no good.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
