Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: crank c123
[Return to Forum]
tuckaway
09-24-2012 06:54:10
76.20.241.106
crank does not spin freely, pistons out,is this normal or is something else binding ?
[Reply]   [No Email]
mkirsch
09-24-2012 13:31:21
64.80.110.74
 Re: crank c123 in reply to tuckaway, 09-24-2012 06:54:10
Who knows why the tractor was parked? It could very well be that it was parked because it spun a main bearing.
[Reply]  [No Email]
tuckaway
09-24-2012 11:00:18
76.20.241.106
i will start taking apart thanks to all.tuck
[Reply]  [No Email]
gene bender
09-24-2012 10:49:15
67.55.227.213
Pull the engine and remove the bearing caps and then you will know why its stuck. You cannot remove crank until the engine is removed. If it was stuck you needed to remove the crank anyway.Pull the engine and tear it down.
[Reply]  [No Email]
CharlieNJ
09-24-2012 10:21:54
76.117.68.151
Tuck, is your engine still attached to the torque tube, or is it on an engine stand?
Charlie
[Reply]  [No Email]
tuckaway
09-24-2012 10:50:51
76.20.241.106
 Re: crank c123 in reply to CharlieNJ, 09-24-2012 10:21:54
still on tractor
[Reply]  [No Email]
teddy52food
09-24-2012 10:07:11
184.94.175.179
Check for a mouse nest around the flywheel or remove the main bearing caps. Maybe a bearing is starting to spin in the block.
[Reply]  [No Email]
rustred
09-24-2012 08:18:53
72.172.100.113
definitly not normal, still tight after two rods out? something wrong. i would be looking from flywheel back for a problem. who know's what else is stuck in there . what is this on?
[Reply]  [No Email]
tuckaway
09-24-2012 08:38:00
76.20.241.106
 Re: crank c123 in reply to rustred, 09-24-2012 08:18:53
c123 farmall 100
[Reply]  [No Email]
tuckaway
09-24-2012 08:10:02
76.20.241.106
shag,el this eng. stuck,pulled head dropped oil pan got it unstuck.spun it over with battery starter 5 sec.took 2and3 pistons out,could not spin crank at pulley or with starter to get 1and4 piston down to remove.got crank to spin enough to remove 1,4 pistons,replacing all rings.crank is still in bind.
[Reply]  [No Email]
El Toro
09-24-2012 12:56:48
108.3.143.30
 Re: crank c123 in reply to tuckaway, 09-24-2012 08:10:02
I think you need to pull the engine. You probably need to do a complete rebuild with a new sleeve kit. How long has it been stuck? You need to pull the crankshaft once you have the engine off. Have the crankshaft measured. Hal
[Reply]  [No Email]
El Toro
09-24-2012 07:23:56
108.3.143.30
I would pull that crankshaft and have it measured for wear. The main bearings may be too tight. You could loosen the main bearing caps to see if that helps. Buy your new bearings from the auto machine shop that measure's your crankshaft. The crankshaft may need a polishing. They won't grind it undersize unless it needs it. Hal
[Reply]  [No Email]
ShaggyM
09-24-2012 07:17:04
50.83.17.32
Do you have the rear main ( felt seal) in place?
Are you in the process of rebuilding this engine?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
