Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: F 12 wont start ideas please
[Return to Forum]
stumpman
09-20-2012 15:33:32
98.18.226.129
My F 12 has always started fine as long as you don't flood it out. It ran about 2 weeks ago with no problems.
I went out today to start her up and she will not go. There is gas from the tank to the bowl side of the pump. I drained the glass bowl a very tiny bit of stuff was in the bottom.
I pulled it with the truck and still nothing. One time we choked it and it tried to sputter but never started up and then nothing after that.
I removed the needle for lack of the right name with the butter fly ears on it on the drivers side of the carb and nothing came out should gas come out of there when you remove that?
The mag clicks every time you turn it over just not sure what else to look for on it. Any help is appreciated.
[Reply]   [No Email]
John M
09-21-2012 03:59:04
67.231.172.230
Re: F 12 wont start ideas please in reply to stumpman, 09-20-2012 15:33:32
Your not getting fuel. The butterfly ear thing is your carb drain. You did turn the fuel back on before starting didnt you. If so take off the line from the pump, crank and make sure its pumping, then work you way to the carb, taking lines loose until you find where its not getting fuel. I suspect one of the discs in the pump is stuck.
  [Reply]  [No Email]
stumpman
09-21-2012 17:31:33
98.22.240.166
Re: F 12 wont start ideas please in reply to John M, 09-21-2012 03:59:04
Quoting Removed, click Modern View to seeThis seems to be the case. I removed the fuel line at the pump and turned it over several times still no fuel Then I tapped on the side of the pump and tried her again and still no gas pumping out. Is that pump rebuildable and if so how hard is it to tackle?
Thanks for all the replies on here.
  [Reply]  [No Email]
El Toro
09-21-2012 03:34:44
108.3.143.30
Do as Teddy suggested checking for hot spark from your mag if there's very weak fire or no fire check the mag's magnets for magnetism. Touch them with a screwdriver. Hal
  [Reply]  [No Email]
Tom Fleming
09-21-2012 02:10:36
173.233.9.252
When you check the points, make sure they are clean. Run a piece of emery cloth through them. Once or twice each contact, and try her again. Also, are the plugs clean and gapped right. Lastly, are the wires copper core?
  [Reply]  [No Email]
Toy Guy
09-20-2012 21:57:06
12.2.142.13
My F-14 one time was runningfine and when I shut it off would not start again. All fuel componets were fine, had spark at mag, but could not get it together. If pulled it eventually start.Finally discovered mag had burnt up my new set of plug wires. Them being new never checked them, over looking the ovious.Replaced plug wires took off on 2nd crank.
  [Reply]  [No Email]
teddy52food
09-20-2012 17:16:33
184.94.175.179
Just because the mag clicks doesn't mean it has a good spark. Pull a wire off a plug & turn the engine over. It should spark every 4th snap of the mag & jump a good hot bluish white spark. If it doesn't, clean the points & check the gap. .012 to .015 should be close. If the mag is hot, squirt a little gas in the carb & try again.
  [Reply]  [No Email]
stumpman
09-20-2012 17:28:57
98.18.226.129
Re: F 12 wont start ideas please in reply to teddy52food, 09-20-2012 17:16:33
Thanks for the advice guys I do appreciate it and will report back as soon as I figure it out.
  [Reply]  [No Email]
oldiron29
09-20-2012 15:48:39
74.88.11.200
stumpman, If it sputtered and tryed to start, you must have spark? Gas should be in the bowl of the carb. they is a little drain cock on the rear side of carb open that and see if you get gas out? Could be your fuel pump is not pumping.
oldiron29
  [Reply]  [No Email]
stumpman
09-20-2012 16:06:00
98.18.226.129
Re: F 12 wont start ideas please in reply to oldiron29, 09-20-2012 15:48:39
Where is the drain cock you are talking about? How can I tell if the pump is pumping ok?
Thanks!
  [Reply]  [No Email]
oldiron29
09-20-2012 16:30:18
74.88.11.200
Re: F 12 wont start ideas please in reply to stumpman, 09-20-2012 16:06:00
Stumpman, If you remove the fuel line from the carb and crank pump you should get a good 7-8"
squart of gas each time pump is under pressure.
The drain cock is at lower back of carb bowl on carb. oldiron29
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
