Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: M Belly Pumo
[Return to Forum]
John M
09-16-2012 05:57:44
67.231.172.230
Neighbors M went a little south on him yesterday. Belly pump will lift, but not go back down. Rod moves, but the plow wont drop unless he loosens the hose going to the cylinder. Now its been years since Ive had to open one, so could someone refresh my memory as to what the problem is.
[Reply]   [No Email]
pete 23
09-16-2012 11:40:34
74.32.238.2
 Re: M Belly Pumo in reply to John M, 09-16-2012 05:57:44
Also, make sure that if he has a quick coupler in line that is not the problem. It happens.
[Reply]  [No Email]
D Slater
09-16-2012 07:43:26
184.15.50.155
Unless the control arm is not moving the shaft going into the liftall housing its going to have to come out. Once the back plate is removed from the reservoir its pretty simple to see and figure out how the linkage works. For some reason the check ball is not being pushed off the seat to let the fluid back, unless the plunger that moves to pump or bypass is staying in the pump position. If its just a problem with the one ball check he may get lucky and move the line and operate it. If pressure line is connected to the right side opening, move it to the left rear or vice versa. Those openings use a different check ball to let the pressure back.
If the internal linkage is apart or broke that works them it won't work though.
[Reply]  [No Email]
Zachary Hoyt
09-16-2012 06:51:40
184.12.64.194
May want to check if the control arm bolt is loose, it can have that effect sometimes. Otherwise the problem is presumably in the valve.
Zach
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
