| Farmall & IHC Tractors Discussion Forum |
Topic: Damaged fill/level/drain plugs
[Return to Forum]
| Author |
[Modern View]
| equeen
09-15-2012 18:43:56
209.102.248.236
 Photo is of a mangled fill plug for final drive. Level plug for trans on Farmall 100 similarly damaged. What is the best way to remove these damaged plugs? Thanks. |
| rhtx55
09-17-2012 17:12:54
207.119.59.96
Re: Damaged fill/level/drain plugs in reply to equeen, 09-15-2012 18:43:56
| Since it is a tapered pipe plug, drill a small pilot hole in the center ( 1/8 in bit) then enlarge to a 3/8 in, then try using the LARGE square easy out and a wrench that just fits, a crescent wrench isn't the answer here.
Before you put in the easy out, use a 3/8 in chisel and make a cut at the top rh corner then try to tap it couterclock wise to loosen the plug. If the chisel starts to chip out the corner STOP. Tap the plug flat face with a ball peen hammer three times, then the easy out should bring it out in 1 piece.
If after all this the plug refuses to move, it's time for some heat. |
| Mark Peters
09-16-2012 12:03:41
66.222.7.148
| I vote for welding a nut on the plug , or if you have access to square steel stock of whatever size that the plug takes (1/2" ?),stick a couple inch long piece in there and weld that in. That being said, if you want to try the easy out method, if you have left hand drill bits, use them and sometimes you get lucky and they`ll catch and back the screw or plug out so you don`t even need to use a easy out. |
| Red Mercury
09-16-2012 09:28:16
204.112.24.251
| | Easy-outs make an excellent Christmas gift for someone you don't like. Rarely do they work if the broken bolt or plug is at all seized in the threads. Often with bolts they will make the problem worse by expanding the bolt in the threaded hole. Or the easy-out will break off in the hole...then what? The other ideas are worth a try and have been successful. Since it is a fill/level plug it likely is not rusted because it would have oil on the other side. Depending how bad the dammage to the plug is I have been able to put the end of a wrecking bar (claw bar) cross ways in the square of the plug and turn it with a big crescent wrench. Heating the casting around the plug at the same time with an oxy-acetylene torch would help as well but will mess up the nice paint job. I only heat something like that as a last resort because of the risk of damaging something else with the heat. |
| John G. Hasler
09-16-2012 11:45:35
174.124.9.28
Re: Damaged fill/level/drain plugs in reply to Red Mercury, 09-16-2012 09:28:16
| > Since it is a fill/level plug it likely is not > rusted because it would have oil on the other > side. And therefor an easy-out is worth trying. I"ve had good luck with them. You could also just drill it out and re-tap for a larger plug. |
| Red Mercury
09-16-2012 20:40:41
204.112.33.4
Re: Damaged fill/level/drain plugs in reply to John G. Hasler, 09-16-2012 11:45:35
| An easy out has very very rarely worked for me. They will work with something that is not badly stuck, but with this old rusty machinery how often is that the case? Honestly, I threw mine in the junk years ago. I have had a lot better luck with an oxy-acetylene outfit or a good tap & die set. It's always good to hear other people's ideas just the same. What kind of easy-outs do you use? Maybe there is something better than the old tapered square ones or spiraled ones I used to have. |
| jimb2
09-15-2012 19:09:40
99.241.38.122
| If you have a welder, weld a big nut on it and use a socket and breaker bar. Heat from weld will also loosen plug. JimB |
| rustyfarmall
09-16-2012 07:22:45
67.55.162.174
Re: Damaged fill/level/drain plugs in reply to jimb2, 09-15-2012 19:09:40
| Quoting Removed, click Modern View to see
I vote for welding a big nut to it also. Yes, the heat may damage that shiny red paint, but that job should have been done before it was painted. |
| equeen
09-16-2012 12:10:38
209.102.248.236
Re: Damaged fill/level/drain plugs in reply to rustyfarmall, 09-16-2012 07:22:45
| | Yep, dummy me didn't pay any attention to the fill/level plug until....after....cleaning and painting. Then .....after....replacing the cleaned and painted oil pan and everything else, decided it was time to lubricate all zerks and refill final drive oil pans, etc. Anyway, thanks to all for responses. I shall eventually clean the paint from the plug, have a bolt or nut welded onto/in it, remove and replace it; then touch-up the area. |
| Centex Farmall
09-15-2012 18:54:22
166.147.123.154
| I've solved this before by driving a snug fitting chisel diagonally, that is, corner to corner and then turning it with a Crescent wrench. |
| edw
09-15-2012 18:52:47
161.11.122.77
| If the remaining part of the plug is threaded I would consider drilling a hole into the center of the plug and use an "Easy-Out" to unscrew the plug. However, other folks on this site will certainly have some better suggestions. Good luck. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
