| Farmall & IHC Tractors Discussion Forum |
Topic: New water pump and belt
[Return to Forum]
| Author |
[Modern View]
| BigTone
09-15-2012 13:42:13
70.192.13.142
I bought a new aftermarket water pump and installed it without adjusting for the fan belt. How do you adjust for the belt, I see a nut and screw? To get the fan belt on, do you put it around the crank pulley then rotate it onto the water pump pulley? |
[Reply] [No Email] | |
| David G
09-16-2012 10:40:20
205.215.206.18
Re: New water pump and belt in reply to BigTone, 09-15-2012 13:42:13
| I would adjust it all the way in with no belt, then put some never-sieze on the threads, open it up all the way, then put the belt on and tighten up. I would also put never-sieze on the setscrew. |
| old
09-15-2012 14:19:51
209.86.226.56
| The water pump pulley is set up so it tightens up or loosens up to adjust the belt from the crank to the water pump. If you look the outer part of the pump pulley can be screwed in or out to make the pulley wider or narrower so that in turn tighten up the belt |
| Jerry/MT
09-15-2012 14:03:24
206.183.116.145
| You use the adjustment on the generator or alternator to tighten the fan belt. |
| Jerry/MT
09-15-2012 14:02:59
206.183.116.145
| rustyfarmall
09-15-2012 14:18:56
67.55.162.174
Re: New water pump and belt in reply to Jerry/MT, 09-15-2012 14:02:59
| Quoting Removed, click Modern View to see
Uh, no. Not on the Farmalls. The pulley on the water pump is made in two halves, and the belt is tightened or loosened by moving those 2 halves closer together (tighten) or further apart (loosen).
Likewise the generator pulley is made the same way.
Find the set screw on the pulley. It will probably have a lock nut on it. Loosen the nut, and then back the set screw out. The outer half of that pulley is on threads, just screw the pulley either in, or out, to achieve the proper tension, tighten the set screw, making sure it is IN a groove, tighten down the lock nut and you're good to go.
The owners manual has pictures. :lol: :lol: |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
