| Farmall & IHC Tractors Discussion Forum |
Topic: Starter
[Return to Forum]
| Author |
[Modern View]
| edw
09-12-2012 15:30:02
161.11.122.77
Hello Folks; Another question about "C" starting difficulty. The tractor is 6volt, positive groud, with a push button ignition. When the ignition is pushed in, the engine begins to turn over but then the starter cuts out. If I relesse the ignition switch and press in again the same thing happens. Thanks for bearing with me. |
| ken house
09-13-2012 02:55:49
173.242.240.50
Re: Starter in reply to edw, 09-12-2012 15:30:02
| C is bad to lose ground. make sure you have a good ground. probably need to ground battery to starter bolt. |
| Ol' Gimpy
09-12-2012 22:40:25
74.67.127.235
| Sounds to me like a starter drive problem.Perhaps drive gear is worn excessively,and/or weak drive spring,makes starter "Kick out" before engine starts.Old Ford bugaboo. |
| edw
09-12-2012 19:28:13
161.11.122.77
| Thanks to all. This really clears up my confusion. |
| gene bender
09-12-2012 16:40:36
67.55.227.236
| So what else have you goofed up as they used a saddle sw you pulled with battery positive cable fastened there. You say a push button sw so something is also messed up or it would start. You must have the wrong starter or you couldnt have a push button to start as original had a button for the sw to make contac and you pulled a rod. |
| charlie M
09-12-2012 16:00:49
74.34.216.81
| Sounds about right when a 6 volt system is in need of some attention. 6 volt systems have to have large gauge cables, clean connections and a good battery to turn over the motor.Anything less and you have problems turning the motor like you described. |
| rustyfarmall
09-12-2012 15:50:07
67.55.162.174
| Quoting Removed, click Modern View to see
Push button? The As, Bs, and Cs all used a saddlemount switch with a rod that you pull. |
| Janicholson
09-12-2012 15:50:42
96.24.99.126
| Terminology is everything, Not a flame at all, trying to help, but ignition is (on a C) is a round button that is pulled out to run and in to stop. The starter switch that makes the starter spin the engine is either a push rod, or pull rod, or possibly a big push button, pushed directly. If the ignition (small) button is pulled out, and the starter switch rod is pushed or pulled (or big button pushed) the starter will crank the engine (turning over with the starter) an engine is not started until it runs without the starter. If the engine starts a little, one cylinder fires, the starter motor will kick out to avoid self damage. If the tractor is having difficulty with carbon on plugs that is the reason the starter stops turning the engine. but the engine does not continue to run. Fix the running issue and I think all is well. Jim |
| old
09-12-2012 15:45:26
209.86.226.32
| Maybe a bad switch or a starter going bad. Best way to know for sure is pull the starter off and take it to you local auto parts store and they can check it for you and 99% of them do it for free |
| Lmack
09-12-2012 15:43:45
24.131.58.167
| Are you saying the engine starts to turn over then the starter releases and the starter "runs away"? If the engine turns over once the engine should crank. You either have a problem with fuel, compression, or ignition. These old engines are very easy to crank if tuned properly. I doubt you have a major problem with the starter if the engine turns over at all. Fix the other issue of tuning first. It could be a worn flywheel ring but I believe you have other problems that need attention first. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
