Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: H popping out of gear
[Return to Forum]
1950 MFD
09-10-2012 21:47:45
71.7.61.9
My father-in-law has a '46 H that wants to pop out of 5th gear. I remember reading about the problem on here, but can't seem to find those posts. Is it a bearing problem or a gear problem? Thank you for any replies.
[Reply]   [No Email]
Owen Aaland
09-11-2012 11:52:22
216.47.35.208
 Re: H popping out of gear in reply to 1950 MFD, 09-10-2012 21:47:45
About nine out of ten times for the ones I have worked on replacing the main shaft front bearing cured the problem of jumping out of fifth. As long as the bearings do not have excessive play the gears can be quite worn before they cause problems.
[Reply]  [No Email]
wisbaker
09-11-2012 11:21:44
184.157.212.173
Like the other said they don't have a lot of power in 5th gear, pulling a load in 5th gear from a stop is a problem so folks figured out how to get it rolling in 4th and bang/force/grind/jerk/powershift it into 5th to get home. After 60 or 70 years of this abuse you see problems like rounded over gear teeth, bent shifting forks and the like. Add in some normal wear and tear and you might have to do some tranny work.
[Reply]  [No Email]
Allan In NE
09-11-2012 06:10:26
148.66.98.174
Bent shift rail.
Allan
[Reply]  [No Email]
todd Hamilton
09-11-2012 11:27:59
174.252.178.61
 Re: H popping out of gear in reply to Allan In NE, 09-11-2012 06:10:26
Tarp strap will fix it. Shifts on the go more difficult with this type of repair.
[Reply]  [No Email]
gene bender
09-11-2012 01:54:41
67.55.226.59
9 times out of 10 the gear is rounded off from shifting from 4th to 5th. Remove top cover then you can get a real view.
[Reply]  [No Email]
Janicholson
09-10-2012 22:01:42
96.24.99.126
Most likely it is a spline wear issue. The 4th 5th sliding gear is a "gear in 4th only in 5th it couples the input shaft to the output shaft for direct drive. (as in many standard transmissions.)
the beating the splines take from grinding from 4th to 5th is the cause. But with a load on a wagon, that is SOP. Try bates equipment for replacement gear/and input shaft. The intermediate pilot bearing in between the shafts can also be worn/broken allowing it to walk out of gear. The ball and spring detents can also be rusted and non functional. Last item is a bent/worn 4th 5th shifter fork. Some of these can be found together contributing to the issue. Jim
[Reply]  [No Email]
sflem849
09-11-2012 04:23:10
69.197.84.39
 Re: H popping out of gear in reply to Janicholson, 09-10-2012 22:01:42
Yep.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
