| Farmall & IHC Tractors Discussion Forum |
Topic: add on 3 point hitch
[Return to Forum]
| Author |
[Modern View]
| alderman
09-05-2012 19:37:09
75.104.96.54
  I picked up a farmall h today with an after market 3 point. I have attached a couple pics showing how they had it hooked up. The pump I"m assuming provides live power to the hydraulic cylinder. My question is to how it is piped up. There is only one line feeding the cylinder and I would assume that a second return line would be needed to enable the hitch to go down. Has anyone ever seen this set up and if so...how should it be set up so as to provide up and down movement of the hitch set up. |
| Allan In NE
09-06-2012 02:54:04
148.66.98.174
Re: add on 3 point hitch in reply to alderman, 09-05-2012 19:37:09
| | The pump/tank/valve is a farm truck hoist unit. You have to hold the lever in the up or down position to make it move because it is spring loaded to the neutral position. Hydraulic power up; gravity down. Allan |
| alderman
09-05-2012 20:19:04
75.104.96.54
| Now that I think about it...I feel kind of stupid...it would make sense that the stabilizer bars would keep it from going down. I'm just trying to figure out the pump now to see if there is a better way than what is there. We are wanting to use a "pull behind" brush hog on this and keep the 3 point set up on it as well. The hog is my father in laws and used hdraulics to raise and lower the deck only. An thoughts on how this could be done? |
| Janicholson
09-05-2012 20:29:49
96.24.99.126
Re: add on 3 point hitch in reply to alderman, 09-05-2012 20:19:04
| The tractor more than likely has a Belly pump that could be used for the Hog. The bars should be used for pulling all implements that are not 3 point. THe belly pump is in the belly of the tractor, and has fittings on both sides. ignore the left side rear fitting as it is a delayed action port. The other two are connected internally, and both are one way hydraulics like the pump now mounted to the engine. The clutch must be out for the belly pump to work. it takes 6 quarts to fill (right side under tank, looks like a big knob) Hytran, or 20 wt non detergent engine oil will work, or what ever is in the tractor now used on the hog to prevent crossing fluids. The rod on the right of the light bar is for the pump. Pull out is lift, push in to the detent on the rod, hold, lift and push farther, lower. Jim |
| Janicholson
09-05-2012 20:10:30
96.24.99.126
| The pins must be removed from the stabilizer bars to allow it to go down. It will also not go down easily even then. It may take a bit of persuasion to get it freed up if it has been stationary for a while. It is a commercial 3 pt, with an unknown pump. It will do fine. The lever pulled down should allow fluid to go back through the same hose as was used to lift. Jim |
| 504
09-05-2012 19:45:59
64.111.61.44
| Power up and gravity down, one hose. |
| alderman
09-05-2012 19:51:47
99.197.128.57
Re: add on 3 point hitch in reply to 504, 09-05-2012 19:45:59
| How much "gravity" is needed? I can stand on the hitch and it will not go down. This one is new to me so I am wanting to learn as much as I can. Picked the whole thing up for a couple old guns on trade. Runs like a top. |
| old
09-05-2012 20:02:45
209.86.226.32
Re: add on 3 point hitch in reply to alderman, 09-05-2012 19:51:47
| But are you pulling the control to the down position when your standing on it??? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
