Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Clutch alignment tool
[Return to Forum]
BigTone
09-05-2012 14:33:29
166.248.6.184
just got the clutch for the M, it came with a alignment tool. can anyone tell me how to use it? The alignment tool has no splines in the part that slides over the tranmission shaft, so how does it align the clutch? thanks for the help, Anthony
[Reply]   [No Email]
Tom Fleming
09-05-2012 18:36:35
173.233.9.252
 Re: Clutch alignment tool in reply to BigTone, 09-05-2012 14:33:29
CNKS shared what I usually do. That is how I put the clutch in the KB5, since I did not have an alignment tool, nor did I have a spare input shaft. However, if you have a clutch tool, it is convenient.
[Reply]  [No Email]
CNKS
09-05-2012 15:08:26
216.144.104.128
Or you can put the bolts that attach the clutch to the flywheel after you pull the two tractor halves together.
[Reply]  [No Email]
old
09-05-2012 14:58:23
209.86.226.40
Just as Rusty says to do it. All it does is hold the clutch disk in place so when you go to put the input shaft in it will fit. If the clutch disk is not lined up as it should be you can not put the 2 halve back together and many a clutch disk has been destroyed because of not have the disk lined up
[Reply]  [No Email]
rustyfarmall
09-05-2012 14:39:47
67.55.162.174
Slip the tool through the splines of the new clutch disc, and then insert the small end of the tool into the pilot bearing in the flywheel. Now you are ready to install the pressure plate.
The alignment tool takes the place of the transmission shaft.
[Reply]  [No Email]
BigTone
09-05-2012 15:39:34
166.248.9.170
 Re: Clutch alignment tool in reply to rustyfarmall, 09-05-2012 14:39:47
Ok, that makes sense...so when I install the pressure plate I use 3 bolts in the plate and 3 bolts to compress the springs and when I put the engine in all I have to do is spin the disk to align with the splines of the transmission shaft, is that right? Thanks Rusty I appreciate the help!
[Reply]  [No Email]
rustyfarmall
09-05-2012 16:09:24
67.55.162.174
 Re: Clutch alignment tool in reply to BigTone, 09-05-2012 15:39:34
No, if the tractor is split, you do not need to compress the pressure plate. Use all 6 bolts and bolt the pressure plate to the flywheel, and when all bolts are tight, remove that installation alignment tool and put it in your tool box. You are done with that tool.
Yes, the transmission input shaft MIGHT need to be rotated a SLIGHT amount for the splines to align with the clutch disc splines, but that can be done by putting the PTO in gear and then turning the PTO shaft by hand, OR, rotate the engine slightly by turning the fan. It will accomplish the same thing.
[Reply]  [No Email]
BigTone
09-05-2012 16:25:55
166.248.9.170
 Re: Clutch alignment tool in reply to rustyfarmall, 09-05-2012 16:09:24
Thats what I was hoping i could do, thank you so much for the help my friend, I appreciate it. ~Anthony
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
