i decided to swap out the manifold on my cub since the exhaust stack refuses to remain attached to the manifold where it joins it, after numerous welding, brazing ect, and i had a good one to put on, it came right off the parts tractor, should have been a 30 minute job, now you know it isnt going to be that easy , and it wasnt, now i got about 1/4 inch of one of the middle studs broke off in the engine of the using cub, right in the middle of mowing season, !@#$, cant even use the manifold flange to keep the drill centered in the hole so since it broke off im figuring a ez out will be about useless as its probably corroded in the block, so what will happen if i use heat around the broken stud on the block to break the corrosion loose? will it hurt the engine, also do these studs go into a water jacket, if i drill thru it? any advise, i really need the cub running today, this all started because it was dying while mowing at part throttle, it had spark,so i blew out the fuel lines, cleaned the sediment bowl, and the cap vent,check for fuel flow, the cub did it again, so i figured i must have trash in the carb, and since i was going to clean it, it was a good time to swap the manifold out too,
