what Fluids for 354 rear end?
Flushing out the differential on my 354, the hydraulics system above it leaked down into the rear and the previous owner just kept adding more hydraulic fluid so what came out was more hydraulic fluid than anything else. Does the rear end take 90 weight gear lube?
Thank you so much for the reply. Now...How much? I can't find a listing for the capacities of this tractor. Does the transmission and differential share a common case? If they don't share the same case...where in the world do you put it in. I have looked the case over, and currently have the lift housing off, so pouring in gear lube is easy. The only plug I can find is on top of the transmission, that is why I wondered if they share the same case. Thanks, Steve
