Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 450 tach cable
[Return to Forum]
P and R Pete
08-27-2012 13:26:59
173.86.60.179
Rewiring my FIL's 450. Noticed that the tach cable was severed, and I want to replace it. In the picture below, I can't seem to extract the old cable at #1. I'm not sure of the purpose of the cover at #2, as the threads seem to be part of the larger casting. Must I take it apart at #3?
Hope somebody has a good word.
[Reply]   [No Email]
D Slater
08-27-2012 13:43:07
184.15.7.159
 Re: 450 tach cable in reply to P and R Pete, 08-27-2012 13:26:59
If the cable won't pull out you have a problem. Just slides in. Housing # 2 holds the drive gear for the tach cable. The two round head screws and retaining plate hold the tach drive housing in. Looks like you have the late type so there's no adjustment needed when putting back in if removed. If lucky the tach cable drive gear is not striped. Wouldn't bet on it though.
[Reply]  [No Email]
P and R Pete
08-27-2012 13:58:51
173.86.60.179
 Re: 450 tach cable in reply to D Slater, 08-27-2012 13:43:07
Thanks.
If I take the two screws out and the retaining plate off, that threaded part will be removable from the larger housing?
If so, will I be able to see that drive gear?
[Reply]  [No Email]
D Slater
08-27-2012 14:06:40
184.15.7.159
 Re: 450 tach cable in reply to P and R Pete, 08-27-2012 13:58:51
Yes
[Reply]  [No Email]
P and R Pete
08-27-2012 14:29:49
173.86.60.179
 Re: 450 tach cable in reply to D Slater, 08-27-2012 14:06:40
Again, thanks. If I can ask one more...
I took off that retaining plate and pulled out the driven-gear into which the cable inserts. (I wasn't pulling hard enough on the cable, and I did get it loose from its gear once out.
I can't see the driving gear- too much wet grease in there, but I put my finger in, and if I was a betting-man, I'd agree that the driving-gear has a problem.
This is my FIL's 450, and I'm replacing the wiring harness. I saw the broken tach cable when I took off the instrument panel and it's hood. If I were to ask him, he'd say not to bother, but while I have it off, it'd be my preference to fix it (just me, I guess), but I don't want to get into a jackpot. If I separate the housing at #3 in my picture, will I be able to replace the driving-gear without special-equipment or getting myself into furthur problems? Or would I have to go deeper than that?
[Reply]  [No Email]
D Slater
08-27-2012 16:58:41
184.15.7.159
 Re: 450 tach cable in reply to P and R Pete, 08-27-2012 14:29:49
If the teeth are good on the gear you pulled out you are probably good to go. If the teeth on the inside gear get to bad the distributor quits turning.
[Reply]  [No Email]
John G. Hasler
08-27-2012 14:39:16
174.124.12.228
Before you invest in any parts make sure the tach isn"t seized up.
[Reply]  [No Email]
P and R Pete
08-27-2012 16:08:46
173.86.60.179
 Re: 450 tach cable in reply to John G. Hasler, 08-27-2012 14:39:16
Nope, the tach"s not seized. I can easily spin the tach-end of the severed cable, and the tach responds.
Any thoughts about swapping out the driving gear?
[Reply]  [No Email]
Janicholson
08-28-2012 09:41:49
199.17.6.160
 Re: 450 tach cable in reply to P and R Pete, 08-27-2012 16:08:46
Shine a good light in there, wipe out excess grease to see the teeth realy clearly. That gear is not usually at fault. There should be a threaded collar on the #1 position of the pic that holds the cable in the drivven gear. It may be off the broken end, or just not shown in the pic. Jim
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
