| Farmall & IHC Tractors Discussion Forum |
Topic: 49 supera
[Return to Forum]
| Author |
[Modern View]
| redpokadot
08-26-2012 17:48:43
96.25.188.58
have a 49 super a can not get any fire out of the mag how power going in no spark to the plugs coming out where the condenser ataches to the mag there is a screw with a nut it spins around and around what is this conected to inside have not taken anything on the mag apart except for the ditributer cap need some help figuring this out |
| gene bender
08-26-2012 20:15:23
67.55.226.123
Re: 49 supera in reply to redpokadot, 08-26-2012 17:48:43
| That screw goes into the hex brass screw which screws onto the threaded end of the condensor in side the mag where that brass screw fastens to the condensor is a wire coming from the coil and another wire going to the points. The screw holdsthe wire coming from the sw to ground the mag to stop the engine. So tighten the hex part. Dont tighten the screw head until the wire from the sw is connected. If you take the cap off over the coil you can see the wires and can check to make sure they are not grounded. Have you removed the mag from the tractor as it mite be out of time 180 and check the wires going to the plugs to see they are in the correct position. Have you replaced the points if you took off the cover the wrong place the rotor mite be out of time also. Removing the cap and turning the engine over you can see the rotor snap then make sure its firing at the tower where the wire goes to the plug. |
| redpokadot
08-27-2012 17:09:13
96.25.188.58
Re: 49 supera in reply to gene bender, 08-26-2012 20:15:23
| thanks for the help i will look at it this weekend when it stops raining and dries up some i have not removed the mag bbut did try to tighten the brass nut it seemed to just spin but will lookat this again this all staryed when i replaced the condenser it was old and when i losened the screw the brass nut began to spin and i could not get it to tighten back up |
| gene bender
08-28-2012 02:19:23
67.55.226.123
Re: 49 supera in reply to redpokadot, 08-27-2012 17:09:13
| There is a clamp to hold the condensor and if its not there the condensor will turn and it hard to get that nut tight without screwing up the two wires on the post. If you need that clamp as i should have one. It fastens to the rear of the condensor. |
| teddy52food
08-26-2012 18:57:09
184.94.175.179
| If it has a mag, you shouldn't have any battery power going to it. The points and coil may be fried. A mag makes it's own power & spark from the rotating magnet. The part that you are turning is connected to the condenser inside. |
| Lmack
08-26-2012 18:21:46
24.131.58.167
| The screw is in the circuit and provides power to the breaker points for spark. Be sure all the connections associated with this screw are clean and power can flow through. There are some test you can run to check connectivity and to verify that the mag is generating enough power for a spark. I have done it for a coil ignition but not for a mag so someone else will have to help. If the screw is loose it may be that the points are not properly installed. |
| gene bender
08-26-2012 20:17:45
67.55.226.123
Re: 49 supera in reply to Lmack, 08-26-2012 18:21:46
| That screw has noting to do with the points it is a connection for the sw to ground out the mag to stop the engine. You shouldnt post when you dont know the facts |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
