Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1086 losing prime, sluggish throttle response
[Return to Forum]
Andrew Psencik
08-26-2012 13:50:28
184.21.67.5
Just went to the local dealer and bought a 1086. Tractor started right up on the lot and ran great. Bought it and got it home, and when i went to get it off the trailer, it started then acted like it was running out of fuel. Put some in, bled the system, and it ran great again. This morning (next day) i went to start, and it did the same thing. Pumped hand primer, and it fired right up. The throttle response is sluggish. Does this tractor have an actual fuel pump or just a injection pump only to pump fuel from the tank ? the fuel filters look like they have been recently replaced. I just hope the inj pump is not weak. Thanks. AP.
[Reply]   [No Email]
Larry B. 1486
08-26-2012 19:21:58
173.190.63.93
 Re: 1086 losing prime, sluggish throttle response in reply to Andrew Psencik, 08-26-2012 13:50:28
My 1486 did that two years ago and replaced the pump, ( plunger ). It screws out and be careful, it has a brass or might be copper washer in the bottom that has to be replaced. $30.00 took care of it. If it starts right up after you prime it up with the plunger on the pump, that what mine did. Nothing was wrong with the pump just the plunger.
[Reply]  [No Email]
Larry B. 1486
08-26-2012 19:26:18
173.190.63.93
 Re: 1086 losing prime, sluggish throttle response in reply to Larry B. 1486, 08-26-2012 19:21:58
I should have said nothing wrong with the injector pump, just the primer pump. I never replaced the injection pump. Larry
[Reply]  [No Email]
Andrew Psencik
08-26-2012 19:26:14
184.21.67.5
Thanks. I'll try that.
[Reply]  [No Email]
wisbaker
08-26-2012 16:21:19
184.157.223.164
Clean fuel, clean tank and clean fuel filters and keep thinking those good thoughts. If this doesn't work and you confirm it is the pump you'll want to have a shiny clean fuel system for the new pump to minimize the potential for a encore performance of the dead injector pump blues. Fuel filters look fresh? Basics mechanics 101- check the last thing that was done in case whoever done it done messed it up. During WWII the RAF did a study on Aircraft mechanical problems not attributed to combat damage, a bomber fresh out of maintenance was twice as likely to have mechanical problems on it's next sortie. I'd also look the fuel system over real good for leaks, rot, damage or patches, it appears there's air getting where you want fuel and remember keep thinking those good thoughts, heck if you're so inclined PRAY for a bad filter or leaky fuel line.
[Reply]  [No Email]
Andrew Psencik
08-26-2012 16:48:04
184.21.67.5
 Re: 1086 losing prime, sluggish throttle response in reply to wisbaker, 08-26-2012 16:21:19
The hand prime plunger leaks really bad when you pump it. If you really shove it in, it bubbles with air when you push it. If you push it normally, the tractor fires right up. It only has to sit for an hour or so to lose prime. The tractor was a local trade in and was supposedly working a baler the day before trading in. I will change filters and fill with fuel before pulling my hair out. How do I diagnose it if it is the pump ?
[Reply]  [No Email]
Allan In NE
08-26-2012 17:46:13
148.66.88.254
 Re: 1086 losing prime, sluggish throttle response in reply to Andrew Psencik, 08-26-2012 16:48:04
Repace that hand pump. That's where the air is getting in.
Allan
[Reply]  [No Email]
DeltaRed
08-26-2012 16:00:56
67.6.225.104
My 1256 did the same thing recently,plus it would die when the throttle was backed off.The pump was shot.A new rebuilt pump fixed the problem.But change the filters first.Check the easy stuff first.Good luck.Steve
[Reply]  [No Email]
scotc
08-26-2012 14:41:10
75.245.113.80
I'd check how much fuel is actually in the tank, and throw a set of filters on it. The fuel gravity feeds through the primary filter, into the back of the injection pump, which pumps it back through the secondary and back into the injection pump to be sent to the injectors.
How long has it sat? You never know what's in the tank, could have a bunch of algae in it even.
[Reply]  [No Email]
mazemeister
08-26-2012 18:00:33
24.187.98.163
 Re: 1086 losing prime, sluggish throttle response in reply to scotc, 08-26-2012 14:41:10
if the tractor has the optional aux. tank under the left fender, then that is correct- gravity flow to the primary filter, when fuel level is near full.
when you're getting low (only fuel left in the bottom tank) the primary filter is under partial vacuum to lift the fuel.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
