| Farmall & IHC Tractors Discussion Forum |
Topic: farmall f12 wont start...need help
[Return to Forum]
| Author |
[Modern View]
| Andrew Kappers
08-24-2012 18:38:22
173.21.98.229
Recently picked up a farmall f12 at an auction with a bad magneto according to the family having the sale. Took it off and had it rebuilt.. Problem is when we put it back on I may have gotten the wire mixed up because it just back fires and blows black smoke when I tried pull starting it...What is the order of the wires from top right of the magneto going clockwise in relation to the firing order on the side of the block..1342?Does the firing order the same as the piston number? so for example the spark plub wire on the magneto that has the 1 by it go the back cylinder closest to the seat? Had a guy stop over who knows a little bout them and kind of helped me get the magneto timed with the engine...we waited till the piston closest to the radiator was at TDC then made sure that the rotor that touched the spark plub wire was lined up...Did we do this right? Weve tried everything and not getting closer...thanks for the help |
| El Toro
08-24-2012 19:09:27
108.3.143.30
Re: farmall f12 wont start...need help in reply to Andrew Kappers, 08-24-2012 18:38:22
| If your No1 piston is at TDC on the compression stroke and the rotor should be pointing to where you would install the No1 sparkplug wire. If the rotor rotates CW your No3 plug is next to be installed and it goes to No3 sparkplug, the next plug wire goes to No4 sparkplug and last goes to No2. Te engine should now start. Hal2-1 4-3 As the rotor rotates CW. |
| F-Dean
08-24-2012 18:51:17
166.249.136.224
| | The cyclinders are numbered from front to rear --cyclinder closest to radiator is cyclinder #1. The wire by the "outlet" with a 1 by it goes to the front cyclinder. Take the mag cover off and have someone crank the engine to make sure the direction that the distributor is turning. Then put the cover back on and insert the plug wires in the 1-3-4-2 order. Don't feel bad, we all have had this problem at one time. Just ask someone with a diesel M. A W-30 will "Run" with the plug wires in he reverse order -- not very well but it will run. At least mine did! |
| rustred
08-24-2012 19:35:16
184.151.222.3
Re: farmall f12 wont start...need help in reply to F-Dean, 08-24-2012 18:51:17
| ya, cause its running on 2 cyl's # 1 and 4 regardless of the wire rotation. |
| Andrew Kappers
08-24-2012 18:56:23
173.21.98.229
| so the next one it hits is in the bottom right outlet of the magneto and the wire would go to the second cylinder back from the radiator? Am I understanding this right? Never been around an F12...just decided to own one for shits and giggles |
| rustred
08-24-2012 19:44:29
184.151.222.3
Re: farmall f12 wont start...need help in reply to Andrew Kappers, 08-24-2012 18:56:23
| NO,the second wire goes to #3 cyl. the third wire goes to #4 cyl. and the last wire goes to #2 cyl. the firing order to each cyl. is 1342 as it comes out of mag.from the 1st wire going clockwise. all these old 4 cyl. tractors have the same firing order not just the f 12. cant explain it any simpler. |
| ken house
08-24-2012 18:47:48
173.242.240.50
| | not sure about rotation. remove distributor cap and turn engine to see which way the rotor button turns. then, 1,3,4,2, on newer motors 1 is closest to the radiator, then 2, 3, 4,. newer farmall models rotor button turns clockwise. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
