Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Clutch, Super H
[Return to Forum]
Wilfam
08-24-2012 10:42:10
71.34.187.17
I have a Super H, 1953. Tractor will not move. If I use the Hand Clutch by M&W Gear it will move a little. Any suggestions or answers.
Thanks.
[Reply]   [No Email]
Janicholson
08-24-2012 18:05:57
96.24.99.126
Re: Clutch, Super H in reply to Wilfam, 08-24-2012 10:42:10
If the PTO operates like it should. (push in the foot clutch, pull the PTO control lever up, Let out the foot clutch and it spins) then the issue is certainly with the M/W clutch, or a blown differential or finals. (all can make it not move but PTO works) The hand clutch is the most likely problem. Jim
  [Reply]  [No Email]
Ol' Gimpy
08-24-2012 16:20:29
74.67.127.235
A guess would be the tabs holding the adjusting nut have sheared,letting the adjustment nut back off.Usually happens when the Aetna bearing seizes from no lubrication.Wasn"t uncommon to get Farmalls in that had the M&W clutch unit welded together,or remove the units altogether if that problem occured,and the owners no longer used the M&W unit.Had a number of them lying around back then,should have held on to them!!
  [Reply]  [No Email]
mkirsch
08-24-2012 11:39:17
64.80.110.74
If it were stuck in two gears, the tractor would not move at all.
Fiddling with the M&W clutch makes the tractor move. That is where the problem is.
For the tractor to move both the foot clutch and the M&W must be engaged. Foot off the pedal, and hand lever forward.
AFAIK, you can lock up the clutches on the M&W by taking the cover off and tightening the large nut underneath. This will effectively disable the M&W clutch's ability to stop the tractor while leaving the PTO running. Pulling the lever will do nothing.
I have the same clutch on my Super M, but I am still trying to figure out how it works, how it adjusts, and if it's even any good. Right now nothing happens when I pull the lever 9 times out of 10.
  [Reply]  [No Email]
glennster
08-24-2012 11:42:41
75.57.143.173
Re: Clutch, Super H in reply to mkirsch, 08-24-2012 11:39:17
i think nebraska kirk has parts for the m+w hand clutches, he may even have the manuals for it.
  [Reply]  [No Email]
Paul Shuler
08-24-2012 10:48:58
170.29.64.4
Sounds like it may be stuck in two gears at one time. You might remove the gear shift lever and look down in the hole and line up the forks so that they are all in neutrel. Hope that is the problem cause its an easy fix.
  [Reply]  [No Email]
sflem849
08-24-2012 11:36:16
69.197.84.39
Re: Clutch, Super H in reply to Paul Shuler, 08-24-2012 10:48:58
The engine would die if that were the problem. Not sure if his is or is not.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
