Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: EXHAUST PIPE ON A M
[Return to Forum]
S2710
08-22-2012 13:20:09
98.143.227.89
I have a M and the pipe is gone on the top where the muffler go on but the pipe is tite in the manifold. Do any of you guys have a way to get the pipe out of the manifold with out breaking anything. I also have a tap to clean out the threads before I put a new pipe in.
Bob
[Reply]   [No Email]
mkirsch
08-23-2012 05:18:04
64.80.110.75
 Re: EXHAUST PIPE ON A M in reply to S2710, 08-22-2012 13:20:09
If the rest of the pipe has rotted away, the part that's still in the manifold is also VERY thin and it will be an easy job to remove.
All you need to do is take a small cold chisel, turn the cutting edge veritcal, and try to catch the edge of the pipe sticking out of the manifold.
Tap it with a hammer and the pipe will cave in and peel away from the threads.
Don't stuff another piece of pipe over the rotted out stub. It's not that difficult to replace the part with a new piece of 2" threaded pipe, and you won't be riding around with the muffler flopping all over the place.
[Reply]  [No Email]
SadFarmall
08-23-2012 01:47:40
121.79.15.250
You may have to use a High Speed Steel Tap and sufficient thread cutting lubricant to clear these threads. You should also take care to remove fragments of metal from the thread in the manifold, which have remained from the exhaust pipe. Most of these remains can be dug out with a small flat screwdriver or a suitable spike.
If pieces of metal are jammed in the threads, the tap is likely to squeeze them tighter and tighter into the thread with the possibility of:
a). damaging or destroying the thread
b). damaging the tap
You should have no trouble cutting thread in cast iron, but remember that 2" is a large diameter, so you are trying to cut or chase out a fairly large amount of thread each revolution of the tap, so patience, cleanliness and thread cutting lubricant (diesel works well) are required. If you see pieces of metal sitting on the flutes of the tap and threatening to choke the cutting teeth, unscrew the tap and wash these pieces off. Good luck.
SadFarmall
[Reply]  [No Email]
Lynn Kaufmann
08-22-2012 20:00:26
76.84.120.75
Use the saws all method. It is a maximum of a 10 minute job. Only problem we found, when I worked in the IH dealer service, the tap would not cut the hard cast iron threads. We tried several taps and the cast iron would just tear the thread cutters off the tap, even on brand new taps. We generally installed the new pipe in as far as we could get it after getting the old pipe out. We also used a lot of anti-seize when we installed the pipe.
[Reply]  [No Email]
sflem849
08-22-2012 20:15:55
69.197.84.39
 Re: EXHAUST PIPE ON A M in reply to Lynn Kaufmann, 08-22-2012 20:00:26
I have heard to cut a couple slits in a pipe and turn it into a tap. BUT if a tap is too soft to work I'm sure a pipe wouldn't work at all.
[Reply]  [No Email]
charlie M
08-22-2012 17:02:20
74.34.216.81
My H had a similar problem - had enough pipe sticking up to get a pipe wrench with a 3 ft pipe on it - came out without problem.
[Reply]  [No Email]
SDE
08-22-2012 14:22:02
174.124.37.94
The muffler should slide down over the top of the pipe. If the pipe is too short, you could go to a muffler shop and get a piece of exhaust pipe to extend it back up to a workable height. They could expand one end so that the muffler will fit in it.
Just a thought
SDE
[Reply]  [No Email]
GordoSD
08-22-2012 17:06:13
64.33.250.162
 Re: EXHAUST PIPE ON A M in reply to SDE, 08-22-2012 14:22:02
No, bad advice. Muffler pipe can't be threaded into the manifold.
Remove manifold from motor.Cut the old pipe off about 3/4 inch above the manifold. Use your asawsall. Now make a cut parrallel to the pipe sides doan into the manifold. Cut just barely into the threads. One cut.
Use punch and collapse the pipe and pull it out. Maximum 15 minute job.
2 inch npt to retap. Blow out all grit and metal. Reinstall new 2 inch pipe about 12 inchesl long.
[Reply]  [No Email]
SDE
08-24-2012 14:21:39
174.124.37.94
 Re: EXHAUST PIPE ON A M in reply to GordoSD, 08-22-2012 17:06:13
But.. But... I am assuming that there is some exhaust pipe still in the manifold. If it is two short to allow enough clearance between the hood and muffler, an extention could be fabricated cheap and easy. I would not even try to stick exhaust pipe in the manifold.
SDE
[Reply]  [No Email]
rustyfarmall
08-25-2012 06:32:34
67.55.162.174
 Re: EXHAUST PIPE ON A M in reply to SDE, 08-24-2012 14:21:39
It is nearly as easy and almost as fast to just fix it right the first time and be done than it is to cobble something together and need to do it all over again in a year or two.
[Reply]  [No Email]
SDE
08-22-2012 14:21:42
174.124.37.94
Just a thought
SDE
[Reply]  [No Email]
sflem849
08-22-2012 13:46:25
69.197.84.39
I would use a hacksaw and cut a chunk out of the pipe. I would then try to cave the rest of the pipe into the middle.
[Reply]  [No Email]
rustyfarmall
08-22-2012 13:46:20
67.55.162.174
You can place a blunt object against the pipe, right next to where it screws into the manifold, strike that object with a hammer, and just sort of "cave it in". That is how I have done a couple of them, and it works good IF the pipe is thin enough.
OR, you can hacksaw the pipe off flush with the manifold, and then using only the hacksaw blade, cut that pipe in 2 or three places down inside the manifold and then dig it out.
[Reply]  [No Email]
SD pete
08-22-2012 14:29:27
24.230.34.249
 Re: EXHAUST PIPE ON A M in reply to rustyfarmall, 08-22-2012 13:46:20
I have done the hack saw blade trick a couple of times and it worked for me.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
