| Farmall & IHC Tractors Discussion Forum |
Topic: IH 140 charging/discharging issues - newbie please advise
[Return to Forum]
| Author |
[Modern View]
| redman140
08-21-2012 20:55:52
96.37.158.78
I'm trying to get the charging system working on my father-in-law's 140. I'm not sure what the year of manufacture was but it is a 12 Vdc system and it has an alternator. My father-in-law says it keeps running the battery down soon after it has been completely charged using a separate charger. I checked the alternator and the best I could tell the alternator has no output. We now have a new Delco Remy alternator but I wanted to better understand the electrical system and verify the tractor is wired correctly before ruining a new alternator. I looked for an ID number on the tractor that might help you know what vintage 140 we have. The only number I found was on the transmission case and it is 58353 followed by a U or J. It's hard to tell from the stamping in the metal. Any help would really be appreciated. I'll be glad to provide any info about the tractor or take any pictures that you need to determine what the correct charging system should be.A couple of questions I had from looking at the wiring are: Does the charging indicator have to be connected in order for the charging circuit to be complete? It is not currently connected. Also, Is that a resistor attached to the rear of the alternator with the wires terminated at each end? Seems like it measured about 30 ohms. No sure what it was for. |
| Jim Becker
08-22-2012 08:30:28
173.74.120.222
Re: IH 140 charging/discharging issues - newbie please advis in reply to redman140, 08-21-2012 20:55:52
| Quoting Removed, click Modern View to see
If that was on a plate attached to the bell housing and if you read the digits correctly, it would be 58353J. The "J" means it has a Rockford clutch, which is irrelevant to the current problem. That is 1976 and I believe that would have been long after IH changed to 12-volts and shortly after they changed to an alternator. You still need to verify as Janicholson said, but that is probably what you will find. There should be some numbers stamped into the alternator, but they may be harder to find and read than the serial number on the tractor. |
| BillyHooper
08-23-2012 06:42:15
64.253.216.185
Re: IH 140 charging/discharging issues - newbie please advis in reply to Jim Becker, 08-22-2012 08:30:28
| I got the charging circuit working with the new alternator and including the charging indicator. Pre-start battery voltage was 11.7 Vdc/ running voltage was 14.4 Vdc. I'm a little concerned that later I measured the running voltage at the battery terminals at 15.4 Vdc. That seems high to me??? I'm worried about over charging the battery. |
| oldtanker
08-23-2012 08:26:25
66.228.255.239
Re: IH 140 charging/discharging issues - newbie please advis in reply to BillyHooper, 08-23-2012 06:42:15
| Quoting Removed, click Modern View to see A fully charge 12 volt battery will be about 13.7-8 volts. And alternator will pur out while charging betweem 14 and 18 volts without hurting anything.
Rick |
| Janicholson
08-21-2012 21:33:54
96.24.99.126
Re: IH 140 charging/discharging issues - newbie please ad... in reply to redman140, 08-21-2012 20:55:52
| To be fair, we need to know if the alternator is original Delco, or replacement newer style with an internal regulator. Looking at the alternator for numbers, or a photo will work. Diagnosis depends on this knowledge. It is very likely that the warning light is part of the problem, but info first. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
