Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: SMTA water in oil pan
[Return to Forum]
Paul A Young
08-21-2012 20:08:10
74.206.50.253
Hi guys I have A SMTA that was getting coolant in oil so I parked it for over a year.Today I went to move it so I thought I would drain out the water from bottom of pan.I drained out what appeared to be a couple of gallons.My question is what is your opinion of where I could be leaking that much into crankcase?
[Reply]   [No Email]
Ol' Gimpy
08-23-2012 13:07:56
74.67.127.235
 Re: SMTA water in oil pan in reply to Paul A Young, 08-21-2012 20:08:10
Don"t like the sound of that!! Seen too many of these get water down the cylinders,usually #3,and then crack the block.Maybe a long shot would be a freeze plug or even a head gasket.Like the guys said,a rain cap is NO sure fire way to keep water out of the engine,water can enter around a muffler seam,or down where the exhaust pipe threads into the manifold,even in rare cases through a burned out hole in the exhaust manifold.Seen them all-let us know just what you find,maybe you will be lucky!!!
[Reply]  [No Email]
rustred
08-21-2012 20:22:38
184.151.222.60
remove oil pan and put a cardboard under it and you should be able to see yourself where its leaking. may have a crack around or in cyl. bore even between sleeve and bore. or could be crack in head. have rad full with water too. you could even remodel a rad cap for and air chuck and give it about 5lbs. of air, but you should have a regulator for this not to blow up the rad or hoses.
[Reply]  [No Email]
504
08-21-2012 20:22:20
64.111.61.44
Pull the oil pan and look up, if you can rent one from a parts house, pressurize the radiator with a tester.
[Reply]  [No Email]
Kenneth R Ohnstad
08-21-2012 20:16:19
174.125.224.67
rain clouds/ condensation
k
[Reply]  [No Email]
sflem849
08-22-2012 07:37:01
69.197.84.39
 Re: SMTA water in oil pan in reply to Kenneth R Ohnstad, 08-21-2012 20:16:19
That is where I was headed, too. 2 gallons is a lot of water to take on from the radiator.
Was the tractor parked inside a shed for the year? If it was outside was the exhaust covered with something that is NOT A RAINCAP. Those things are junk for outside storage. They are ok if you get caught in the rain.
[Reply]  [No Email]
Paul A Young
08-22-2012 18:09:41
74.206.50.252
 Re: SMTA water in oil pan in reply to sflem849, 08-22-2012 07:37:01
Inside and it was all anti-freeze mix
[Reply]  [No Email]
sflem849
08-23-2012 13:32:06
69.197.84.39
 Re: SMTA water in oil pan in reply to Paul A Young, 08-22-2012 18:09:41
Hmm, there goes the easy answer!
[Reply]  [No Email]
Paul A Young
08-22-2012 05:46:42
74.206.50.254
Thanks for replies won't get to it now till after harvest.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
