Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: C Countershaft Nut, Ring and Pinion Questions
[Return to Forum]
TMatt
08-16-2012 20:18:32
70.59.171.247
On a C I'm having troubles getting the ring and pinion set right. My problem is, when I tighten down the countershaft nut, it pulls the pinion gear out too far to properly mesh with the bevel gear. I've taken all the shims out and it's still set out too far.
When I took it apart, the countershaft nut was barely finger tight. When I put the nut on like it was, the gear mesh looks real good, until I roll it the other direction and the whole countershaft moves about a 1/8th inch out of the case. The cast cover over the nut was cracked when I took it apart so I wonder if this is how it was before?
Could something be worn down causing this extra slack, or did I miss something?
Am I correct that adding shims behind the countershaft front bearing flange will move the pinion gear out farther from the ring gear?
Thank you
[Reply]   [No Email]
Haas
08-18-2012 16:42:11
75.201.239.196
 Re: C Countershaft Nut, Ring and Pinion Questions in reply to TMatt, 08-16-2012 20:18:32
Have you checked the parts diagram to make sure all the parts are in there. The parts diagram shows a spacer on the countershaft between the back bearing and the 1st speed gear. If that spacer is missing I think you would have the problem you describe. Looking at the parts diagram, it looks like that spacer may be hidden inside the oiler gear. Anyway, a spacer there would push the pinion gear back.
[Reply]  [No Email]
TMatt
08-19-2012 20:01:29
70.59.171.247
 Re: C Countershaft Nut, Ring and Pinion Questions in reply to Haas, 08-18-2012 16:42:11
Thanks for the reply.
Turns out there were two things causing my trouble. First, I found that the edge of the boss of 4th gear where it meets with the front bearing was badly worn.
Also I pulled out the spacer next to the rear bearing and found it had about an 1/8th inch groove worn in it too. I swapped these out and the pinion depth looks great.
Thanks again
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
