| Farmall & IHC Tractors Discussion Forum |
Topic: Farmall SMD Doesn't Run Smooth At Idle
[Return to Forum]
| Author |
[Modern View]
| FarmallDaniel
08-15-2012 21:29:16
68.117.50.178
I have purchased a smd farmall that doesn"t run smooth at idle however if you work it at all with a load it runs fine it has a rebuilt head on it kind of smokes some blue at idle do I have injector issues or timing of pump or ??? anything to try be great |
| Janicholson
08-16-2012 05:34:35
199.17.6.86
Re: Farmall SMD Doesn't Run Smooth At Idle in reply to FarmallDaniel, 08-15-2012 21:29:16
| Some things to try. Modest compression loss (rings or leaky valves) can be exaggerated at low speeds where there is time for leakage to make a difference. A check of compression on the gas start cycle will check differences between cylinders (they should be within 8 to 10 % of each other) Poor injector pattern at low flow will also produce the issue. Find the missing cylinder/s by cracking loose the injector lines at the pump when running to find the ones not firing. Then swap the injectors between those and running cylinders. If the misfire follows the injector, the injector is in need of rebuild. Pumps and timing can be a factor, but the others are more likely. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
