| Farmall & IHC Tractors Discussion Forum |
Topic: Strange Super H Noise in tranny
[Return to Forum]
| Author |
[Modern View]
| Too Far Gone
08-15-2012 14:44:00
67.221.197.94
Its a stage 2 tractor.It seems to omly make the noise in 1st - 4th gears and reverse.All gears work good,but has a clunk-clunk -clunk noise somewhere under foot when moving.It has disc brakes that work good.The coupler on the input shaft is tight,but the front bearing seems to have a small bit of wiggle,Might be it?Noise dont change speed much at all in 1st or 4th |
| Zachary Hoyt
08-15-2012 16:18:40
184.12.70.98
Re: Strange Super H Noise in tranny in reply to Too Far Gone, 08-15-2012 14:44:00
| My H did that after I installed Super H gears in it and with the help of Janicholson I discovered that I had a cracked tooth that had broken off under load on the lower constant mesh gear at the front of the transmission. Every time the broken tooth came around it would clunk. Luckily I had another spare gear on hand and was able to change it out and the noise went away. You could probably diagnose the problem by removing the belt pulley drive or cover plate and peering in at the constant mesh gears while turning the engine over with the ignition off. In my case it was quite visually apparent what the problem was. Zach |
| Too Far Gone
08-16-2012 06:26:56
67.221.197.94
Re: Strange Super H Noise in tranny in reply to Zachary Hoyt, 08-15-2012 16:18:40
| Mine stops the noise while still rolling in gear if I clutch it.Did yours do that too?Thanks for the help |
| Zachary Hoyt
08-16-2012 09:03:46
184.12.70.98
Re: Strange Super H Noise in tranny in reply to Too Far Gone, 08-16-2012 06:26:56
| yes, that is right. The constant mesh gears are still turning but are not under load, so the noise is not noticeable among all of the other sounds the tractor is making. This is also why it is not audible in 5th gear, because the countershaft is not under load. Another way to check would be to hook the PTO to a load and run it in place, the noise should be present. Zach |
| Too Far Gone
08-16-2012 11:51:48
67.221.197.94
Re: Strange Super H Noise in tranny in reply to Zachary Hoyt, 08-16-2012 09:03:46
| I guess Im gonna have to learn how to work on tranny gears.Im good on engines,but never tackled those dang gears before.I suppose pull top off of tranny? Can you leave the brakes in place to do this job?Or does everything come out?I'll have to dig into it in the coming weeks as winter draws closer.I will probably need more help yet,but I sure do Thank You for your help so far too! |
| Zachary Hoyt
08-16-2012 12:32:30
184.12.70.98
Re: Strange Super H Noise in tranny in reply to Too Far Gone, 08-16-2012 11:51:48
| If it is the upper constant mesh gear you can replace it through the bottom of the clutch housing after removing the belly pump(if so equipped) and the input shaft. If it is the lower constant mesh gear you will have to pull the gas tank, belt pulley drive, etc and I would recommend that you remove the seat and unbolt the steering column and hang it from the ceiling. The the transmission top cover comes off and you are looking at the gears. The upper shaft comes out with three bolts and the countershaft comes out once the nut and snap ring are removed. Zach |
| Too Far Gone
08-17-2012 08:02:10
67.221.197.94
Re: Strange Super H Noise in tranny in reply to Zachary Hoyt, 08-16-2012 12:32:30
| Thanks a million for the directions.Email me ,and I'll keep you informed on my progress.Thanks Again |
| CNKS
08-15-2012 14:56:27
216.144.104.128
| You can replace the front bearing by removing the belt pulley and the cover below. At least that worked on my Super M. To go any further you have to remove the trans cover. No need to split the tractor. |
| Too Far Gone
08-16-2012 06:29:48
67.221.197.94
Re: Strange Super H Noise in tranny in reply to CNKS, 08-15-2012 14:56:27
| I thought it kinda looked that way,but I dont think that little bit of slack is my noise.It actually stops making the noise while rolling in gear if I clutch it,then starts again as soon as clutch is let out.Thanks for any help |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
