| Farmall & IHC Tractors Discussion Forum |
Topic: Farmall 400 or 450
[Return to Forum]
| Author |
[Modern View]
| DC_PA
08-14-2012 21:32:23
24.101.97.252
Hi! I got Farmall 400 tractors, I just got another but it has a 281 motor in it. How can u tell 400 and 450 tractors? Are there any distinct differences in 400 or 450's? Any help would be appreciated. Thanks |
| LarryM
08-15-2012 11:00:46
146.151.183.162
Re: Farmall 400 or 450 in reply to DC_PA, 08-14-2012 21:32:23
| The late 400s had a c-281 in them. |
| LarryM
08-15-2012 11:00:03
146.151.183.162
| The late 400s had a C-281 in them. |
| D Slater
08-15-2012 05:29:42
184.15.20.202
| Short answer, if you can only find a serial number on the ID plate. Look for the number on lever that operates the T/A clutch shaft. ITs on the left side and the rod from T/A operating handle goes to it. Serial number 27067 or lower and the 6 digit number starts with 366, = 450 chassis. Any serial # below forty some thousand and a lever # starting with 359 = 400 chassis. Maybe not that short of answer. |
| DC_PA
08-15-2012 19:49:24
24.101.97.252
Re: Farmall 400 or 450 in reply to D Slater, 08-15-2012 05:29:42
| Serial number is 15611,.. Nothing else is readable on the tag. Does that mean it a 450? |
| D Slater
08-16-2012 06:29:50
184.15.20.202
Re: Farmall 400 or 450 in reply to DC_PA, 08-15-2012 19:49:24
| Look close at the lever that the t/a handle moves when shifted on the side of clutch housing. See if a part # can be read. If its 359507R1 thats a 400 chassis. If its 366352R1 its a 450 chassis. The serial number you posted could be for a 400 or 450. I just mentioned the serial number break in case IH stuck the 450 lever in some of the last few 400 tractors. They would have a over 40,000 serial # though. way above what the 450 tractors went to. 400 tractors also have a clutch pedal travel stop bolt in the very bottom of the pedal. It has a square head with a jam nut. 450 tractors didn't use the bolt. Lots of other things to look for but none are fool proof after the years since made. 450 used a all plastic covered steering wheel that went on a splined shaft. 400 was keyed and just covered on the outer ring. 450 used a key switch below the instrument panel. 400 in the panel. To ID the engine look for a serial number on a raised flat place in the block casting just above the sheet metal cover on the oil filter side of the block. If no number can be found it may be a replacement block. If is has a serial it may tell what tractor it started in. Guess you found C-281 on the block. Look forwar on the block from it to find a date code. Raised cast numbers and letter. Like 4-8-C. Thats the month and day casting was made with the letter representing a year. Depending on numbers and letter you have can tell when the block was made. |
| mkirsch
08-15-2012 05:20:50
64.80.110.74
| Whatever the serial plate says it is, it is.
Lacking a serial plate, you will find that a 450 almost always has C (1957) and D (1958) date codes in the castings.
There will be holes in the top of the cowling over the hydraulic valves so that you can switch them from one-way to two-way easily.
Odds are, if the hood emblems say "400" it's just a 400 with a replacement engine. Of course, anything could've happened in the last 55 years. |
| Hugh McKinney
08-15-2012 10:01:42
99.195.66.81
Re: Farmall 400 or 450 in reply to mkirsch, 08-15-2012 05:20:50
| I have a 450 that has the holes in the cowl, but what do you mean by one-way or two way? I have not used remote cylinders on it, just pulling an old-fashioned Servis stalk-cutter, so I don't know much about their hydraulics. Thanks. |
| dblair
08-15-2012 16:03:30
68.57.49.167
Re: Farmall 400 or 450 in reply to Hugh McKinney, 08-15-2012 10:01:42
| you can set a 450 hydraulics for one way or two way operation at the valve. |
| DeltaRed
08-14-2012 22:46:51
67.6.225.104
| Look at the sn plate....Steering wheel,white hood stripe.look at the cast codes.may or may not be the original engine.He!!,I got a friend with a late 450 that has a 248 in it. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
