| Farmall & IHC Tractors Discussion Forum |
Topic: Governor on H Farmall
[Return to Forum]
| Author |
[Modern View]
| Kenneth Blackwelder
08-13-2012 18:06:58
166.82.5.121
How does it get oil to the governor? I'm not getting any oil. |
| D Slater
08-14-2012 07:53:28
184.15.20.202
Re: Governor on H Farmall in reply to Kenneth Blackwelder, 08-13-2012 18:06:58
| First place to check is between the governor housing and the front cover. If someone siliconed in place of or on the gasket the oil pressure passage may be pluged. Or if someone made a gasket the slot opening may be left out from front cover plate to the governor housing oil feed hole. Next to check is recent work under the front engine cover or cam bearing recently installed. If none of the above the small metering hole may be pluged from a dirty engine. Oil pressure is not fully sent to the governor housing and idler gear through 360 degrees rotation. Think a slot in the front cam journal just sends oil pressure to the passage so many degrees a revolution. If the cam bearing is installed with holes in the correct place. I may not remember everything about the oil system but the governor is not a complete splash system. Maybe some to the drive gear and front bearing is all. |
| rustyfarmall
08-14-2012 08:04:19
67.55.162.174
Re: Governor on H Farmall in reply to D Slater, 08-14-2012 07:53:28
| Quoting Removed, click Modern View to see
Correct. "splash system" was probably the wrong term to use. Probably should have used "intermittent" instead. I do know IF the system is working, you WILL know it if you start the engine while the cover is off the governor. |
| rustyfarmall
08-14-2012 05:02:41
67.55.162.174
| It is a "splash" system. Take the cover off, start the engine, and then see how much oil gets to the governor. |
| D Slater
08-13-2012 18:59:12
184.15.20.202
| From the front cam bearing bore over to a opening in the front engine cover plate, over to a opening near the front top of the governor. Same passage oils the idler gear bearing. If you remove the governor housing from the engine you can see the outlet. Least thats how I remember the path of the oil. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
