Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Farmall Super H 12v conversion
[Return to Forum]
Dragonclaw
08-08-2012 15:23:22
69.11.163.106
OK Have done the conversion following the guide on here for the super M (http://www.ytmag.com/articles/artint195.htm) along with the advice given to me in my previous posts.
For the alternator bracket I took the advice given and just flipped the regulator bracket over and drilled out the hols bigger and it lined right up. The only problem im having now is in the past my grandad replaced the regulator belt and replaced it with one longer then stock. He then made a spacer on the top support in order to extend it to make up the difference. Now the belt is way to long for what I need it for.
What i did was take a piece of wire and use that to measure the size of the belt needed. If it matters the wire i used was actually the plug that you would use to plug in a ATX computer power supply with both ends cut off of it, since i have about 20 or more of those laying around. Anyway after putting it on there and cutting it to fit the gap exactly it measured 29 1/4 inches. That is with the Alternator slam up against the valve cover. So i figure i need about a 29.5 to 30 inch belt to fit there so that I will have some adjustment on it to get it off the valve cover.
Does this sound about right to you guys/girls?
[Reply]   [No Email]
Dragonclaw
08-10-2012 16:32:50
69.11.163.106
Re: Farmall Super H 12v conversion in reply to Dragonclaw, 08-08-2012 15:23:22
Everything seems to be working great thank you all for all the help.
I'm fairly certain if i run into any other problems it will either be that the coil is messed up (was not replaced, and has run hot before) or the resistor i used was not rated for the right amperage and has burned up.
O and just for future info in case some one does a search for this info and finds this post the belt we used was 31 inches.
  [Reply]  [No Email]
Janicholson
08-10-2012 18:36:17
96.24.99.126
Re: Farmall Super H 12v conversion in reply to Dragonclaw, 08-10-2012 16:32:50
ou are welcome. When running there is no current flowing through the resistor, only when the ign. is on and it is not running, or as it comes to a stop when the ign. is just shut off.
so it is going to work (opinion) for a long long time. Jim
  [Reply]  [No Email]
Dragonclaw
08-09-2012 14:50:08
69.11.163.106
yeah i used that one. I would have gone with a bulb but the only bulb holder i could find laying around was for a 194 type bulb. I couldn't find anywhere on the net to tell me if that was a 200 ma bulb or no.
Anyway we wont have the belt to put on it till tomorrow but hopefully it will work out.
  [Reply]  [No Email]
Mark-Mi
08-09-2012 06:31:57
68.66.31.18
Original belt from dealer should fit.
  [Reply]  [No Email]
mkirsch
08-09-2012 05:32:56
64.80.110.74
The warning light goes to the #1 (ONE) terminal on the alternator.
#2 gets connected directly to the BAT post.
Go to your nearest Radio Shack and pick up a package of the biggest diodes they have. That's all you need.
BTW, the alternator warning light in a car performs the same function there as it does on the tractor... Not only does it tell you when the alternator isn't charging, it "excites" the alternator and makes it start charging.
Normally you think of an electricity-making device as having magnets. Have you ever noticed your tools do NOT stick to the alternator? No magnets. It's all done with electromagnets, hence the need to "excite" the alternator, aka charging the electromagnets.
  [Reply]  [No Email]
Dragonclaw
08-09-2012 04:48:53
69.11.163.106
I found one that says 15 OHM but it says "15 OHM 1WJ 15 OHM" does the 1 wj mean its only 1 watt?
Actually i found 2 Brown-Black-Black- Gold ones but i have no clue what wattage they are and one of them is like 2x the size of the other one.
This post was edited by Dragonclaw at 05:15:47 08/09/12.
  [Reply]  [No Email]
Janicholson
08-09-2012 09:48:26
199.17.55.151
Re: Farmall Super H 12v conversion in reply to Dragonclaw, 08-09-2012 04:48:53
Use the big one and see if it works, It will not cause smoke. Jim
  [Reply]  [No Email]
Dragonclaw
08-08-2012 17:00:11
69.11.163.106
This is the diagram I used. I ran all wires as shown other then the #2 off the alternator running to the warning light and then the warning light to the switch.
I assumed the warning light was there so you would know when it is chrageing and when it is not like a BATT warning light in a car. So i assumed that it didn't matter i just wouldn't know whether it was chargeing or not with out the ammeter or a voltage tester. If my assumption was incorrect and it does in fact need a light there to complete the circuit i will install one, but if it will operate with out one id rather leave it off as I done see the need since the ammeter will tell me what voltage the tractor is getting.
Just let me know one way or the other, I'm sure i can pull a 12v light housing out of some scraped car or part tractor we have laying around to make one.
EDIT: SO i goggled it after posting this and it seems i need to either put the light on or add a resistor but the wire has to be run back to the switch one of those ways. If that is what you where trying to tell me in your previous post I am sorry i did not understand it.
If i go the resistor route what kind do i need, i have ALOT of old computer parts laying around i could rob one off of if any of those would work.
EDIT AGAIN: After goggling some more and then rereading Jim's post i see that he already answered these questions i just didn't understand what he was saying at the time. Thank you very much Jim.
This post was edited by Dragonclaw at 17:39:29 08/08/12 3 times.
  [Reply]  [No Email]
Janicholson
08-08-2012 17:45:09
96.24.99.126
Re: Farmall Super H 12v conversion in reply to Dragonclaw, 08-08-2012 17:00:11
The wire is needed, it will not charge correctly without it. The resistor can be between 10 and 15 ohms and more than 5 watt. The colors are brown black black, or black yellow black. Or wire the leads from a bulb style marker light one lead the the alt, and one to ignition. Jim
  [Reply]  [No Email]
David G
08-08-2012 16:57:13
205.215.206.18
Do what Jim suggests, and you need a little slop to get the belt on.
What is length of stock belt?
  [Reply]  [No Email]
Dragonclaw
08-08-2012 16:35:50
69.11.163.106
Ok so i messed up Everywhere i typed regulator i meant Generator....
ALSO i did not put in the the warning light in there as the wiring guide showed. I just didn't hook that wire on the alternator to anything and caped it off with a wire nut and electrical tape. I'm assuming it will still work without he light, If I'm incorrect let me know.
Edit: Thank you for the reply. the belt he had on there was to wide for the pully on the Delco 10SI but i know we have a few belts laying around off old Toyota's that i can cut to do this that are the right width.
This post was edited by Dragonclaw at 16:38:58 08/08/12.
  [Reply]  [No Email]
Janicholson
08-08-2012 16:47:20
96.24.99.126
Re: Farmall Super H 12v conversion in reply to Dragonclaw, 08-08-2012 16:35:50
The light, (or diode with band toward alternator, or 10 ohm resistor) connects to the ignition voltage at the coil where it attaches to the ignition switch wire. The diode, light, or resistor is needed to supply excitation voltage to the alt. The resistor, diode, or light prevent the alternator from keeping the engine running when the ignition is shut off.
the coil should be hooked up so that the negative terminal goes to the distributor. (assumes it has a coil ignition, not a Mag.) with a mag, other steps are needed. Jim
  [Reply]  [No Email]
Janicholson
08-08-2012 16:34:33
96.24.99.126
If the old belt will not be used, cut it, and stretch it around, then cut it again to the length needed. This gives a "in the V" length, and can be used at the store to assure it will work. Jim
  [Reply]  [No Email]
DeltaRed
08-08-2012 17:54:48
67.6.225.104
Re: Farmall Super H 12v conversion in reply to Janicholson, 08-08-2012 16:34:33
I use that same method...
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
