Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 706 TA replacement
[Return to Forum]
Senator
08-05-2012 17:22:10
72.37.249.84
I've got an opportunity to purchase a 706 with a blown TA for next to nothing. Tractor is in pretty decent shape otherwise.
Been wrenchin' on all kinds of equipment for years, but never worked on a TA. Is it pretty much a bolt up replacement job (will buy a rebuilt TA) or is there some specialty set-up I need to be aware of?
If I procede I will get a drive train service manual, but some imput from y'all would help with my decision.
[Reply]   [No Email]
Owen Aaland
08-06-2012 16:47:56
216.47.35.140
Re: 706 TA replacement in reply to Senator, 08-05-2012 17:22:10
The instructions in the service manuals are for pretty much just swapping the parts, nothing about shimming things to control the end play. That came about with the aftermarket rebuilders. You will not find shims available from IH, just the aftermarket. By maintaining closer tolerances the life of the TA can be extended beyond what you would normally get.
  [Reply]  [No Email]
todd Hamilton
08-05-2012 19:52:41
174.252.147.31
Is it all bad or just out on the low side? While very handy, unless you are going to plow with the tractor you still have 8 forward gears if the high side is functional for now. It might run for years that way, cousin's 886 did engine block finally failed after 30 years. 1066 was out on low side too.
  [Reply]  [No Email]
charlieu
08-05-2012 19:35:02
206.53.193.95
Here are a few pictures of a TA handler stand that I have designed for doing a TA job. It allows you to safely handle the big housing. These pictures were taken doing a TA job on a 986. When I do a TA job on an 06 series tractor I just hang the fuel tank and steering pedestal and remove the TA much like a 86 series. I can walk you through the process if necessary. More pictures can be seen on my web site, www dot charliesrepair dot com
  [Reply]  [No Email]
Senator
08-06-2012 07:17:01
75.94.36.133
Re: 706 TA replacement in reply to charlieu, 08-05-2012 19:35:02
Thanks to all for the info. Looks like a job I can handle, this will be a winter project so time isn't an issue.
Charlieu - I like the look of that handler you built!
  [Reply]  [No Email]
The tractor vet
08-05-2012 19:04:56
76.212.234.198
One of my favort jobs , putting a T/A in . About 23 hours of work to do it correctly . It is not just a matter of unbolting and stuffing a rebuilt unit in as you need to set the end play of the quill then shim the lower shaft gear to what shim-s you used to set end play . then there is getting the lower shaft nut tightened up correctly then drilling it and installing the safety roll pin . Next is going thru the MCV and checking spring lengths and tension and or installing a new spring kit along with checking each valve for free movement and also having a few special tools to do this with . Yes you can just STUFF one in and hope it lasts or ya can do it right and it will last for years.
  [Reply]  [No Email]
andrew hegeman
08-05-2012 18:32:50
173.109.24.157
its not as bad as they make it out to be. depending on the condition of the other parts in the trans it is an easy weekend job.(unless its a cabbed tractor) it also helps to have a splitting stand. put a new mcv pump in while u have it apart too.
  [Reply]  [No Email]
RSFARMS
08-05-2012 17:50:58
166.182.3.181
A TA INSTALL IS A MAJOR JOB BUT IF YOU HAVE SOME TRANMISSION EXPERINCE IT CAN BE FIGURED OUT BUT I WOULD ALLOW AROUND $2000.00 FOR THE REPAIRS.
  [Reply]  [No Email]
cole in mo.
08-05-2012 17:44:42
65.255.149.240
Its not an afternoons job, hood, gas tank, floor pan, steering post have to come off. Split the tractor at the clutch housing, split it again behind the range trans. The part in the center is the speed trans, its got the ta in it. Lots of gears to come out, the ta is the last thing, and the first to go back, its heavy too.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
