Rear axel removal B414
Iamarv
I cannot get the rear axel out of my International B414. (industrial) I got it to move a few inches...now it is stuck. The bearing needs to be replaced. Any suggestions?
Hi, I believe you must remove the hydraulic reservoir that is under the seat so you can remove the bolt and C-clip that is on the end of the axle on the inside of the bull gear.
I have never removed an axle myself but neighbour broke an axle on his 434 once and he had to remove hydraulic reservoir to remove axle retaining C-clip and bolt.
Hope this helps
JimB
