| Farmall & IHC Tractors Discussion Forum |
Topic: can a cummins motor fit in a 560
[Return to Forum]
| Author |
[Modern View]
| dundeeaj
08-02-2012 13:34:56
70.198.4.210
I want to see what your thoughts would be about putting a cummins motor in a 560 diesel |
| dundeeaj
08-03-2012 21:13:04
70.198.2.78
Re: can a cummins motor fit in a 560 in reply to dundeeaj, 08-02-2012 13:34:56
| I got a 706 pump on it now so if I go though the head and have it ported and polished would that help |
| sflem849
08-04-2012 09:56:44
166.182.3.134
Re: can a cummins motor fit in a 560 in reply to dundeeaj, 08-03-2012 21:13:04
| Quoting Removed, click Modern View to see
Porting and polishing will help it floe air better, faster, and smoother. It probably wouldn't help at all with starting. Taking it in and having the valves ground and milling it will sure make a difference (if that is your problem) In my brief experience there are a lot of tractors out there that need the valves adjusted or even ground. The head work shouldn't be too much. Maybe $300 if you don't need a bunch of new valves.
With a good compression tester you should be able to determine if your low compression is being caused by your rings or your valves. |
| Huskers86
08-04-2012 08:12:32
70.198.5.17
| Quoting Removed, click Modern View to see I'm guessing. The pump is weak or maybe low.
Compression is the problem. It could be injectors. I don't want to steer you the wrong way and waste your money. You can pull your pump and get it bench checked at a diesel shop for a start. |
| mkirsch
08-03-2012 05:27:39
64.80.110.75
| The adapter plate for the 06 and 56 series "large frame" tractors also fits the 560, so you could hang a 3.9L (4BT) or 5.9L (6BT?) in the tractor pretty easy. Like the other guys said, it ain't cheap, though.
The 3.9L would give you about "stock" horsepower, and wouldn't be too heavy. Only thing is, the engine is not a lugger. Dad's got a 5220 Maxxum on the farm with the 3.9L and ya gotta keep 'er wound up over 1500 RPM or it falls flat on its face. That's my only complaint about that tractor.
Unfortunately a 560 won't sound right with a 3.9L. |
| dundeeaj
08-03-2012 05:21:50
70.198.2.78
| I am not looking for more power I just want a tractor that starts better and yes I have new glow plugs new wiring and two 12v betters hooked up in line and I still have to use ether to git it to start |
| Huskers86
08-03-2012 19:40:36
64.147.41.36
Re: can a cummins motor fit in a 560 in reply to dundeeaj, 08-03-2012 05:21:50
| Quoting Removed, click Modern View to see Get your injecter pump rebuilt. Did that to my 460 years ago and it starts right up and everyone knows a 560 starts better than a 460. Hope this helps. |
| farmallboy15
08-03-2012 08:08:58
184.20.168.81
| If it has all new glowplugs and batteries maybe it is your valves causingthe hard starting? M&W made a turbo kit for the 560, if you can find one and wanted more power. |
| Va Gasman
08-03-2012 04:13:35
75.197.9.240
| Remember what Johnny Cash said about a little bit of help from an a-dapta- kit, so that it would fit" |
| Fixerupper
08-02-2012 19:41:23
100.42.82.164
| | Are you planning to put a 5.7 in it? One thing you will gain is it will start a LOT easier. It would be a peppy tractor and fun to drive but I wouldn't take it to the field and pull five bottoms with it. Neighbor had a 560 diesel that was turboed and putting out 107 horses on the dyno. It was set up that way when he bought it. Fun to drive and they never had trouble with it, but the keyways in the axles were chipped from the extra torque. It must have had the rear end updates. Jim |
| Erik Dekeyser
08-02-2012 18:33:32
184.151.63.255
| It will fit but you have to buy an adapter plate and they arent cheap. I have been looking at a cummings for a 544 the motor isnt to expensive but its about 2 grand for the plate and then there is the rad and maybe the fuel tank and so on. Its much cheaper to stick with the IH engine. Well thats what i found out so far. Erik.. |
| wisbaker
08-02-2012 17:49:35
207.118.135.5
| What's the purpose? Remember the 560 was the tractor IH put into production delivered to the public and then found out the rear ends weren't up to snuff. They came out with an upgrade kit but putting more power to one would make me nervous. If you're looking to repower at the same power it might be okay but put some long range glasses on- Even if you have the tractor and an engine unless you have access to a machine shop it'll probably cost you just as much to adapt a Cummins as it would to put an IH motor back in it and when you're done what will it be worth? Basically anything can be made to fit, how much money do you have and what purpose will it serve when you are done? |
| rhtx55
08-02-2012 17:27:18
207.119.62.8
| What model of Cummins are you referring to ?
NT855, NTH, NTC, Big cam, Big cam IV, L10, M11, N14, Triple Nickel,K model, or something along the lines of a modern 4BT, 6BT, 6CT, IBX, ISX??
You can make just about anything fit with an adapter and flex plate, just have to be conscious of how much torque & vibration you would be putting through the 60 year old tranny, rear end, and final drives. I would also consider how much (if any) extra weight that it will place on the front end. Just consider the longevity of the modification, and the purpose you will be using the tractor for, just shows or working it.
This day & age, anything is possible, just depends on how far you want to take it.
This post was edited by rhtx55 at 17:30:59 08/02/12. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
