Topic: 12V conversion wiring shortcut
[Return to Forum]
| Author |
[Modern View]
| mkirsch
07-31-2012 07:39:04
64.80.110.75
I want to do a quickie 12V conversion on Dad's W400.
1. The battery's shot.
2. The old charging system isn't working 100%.
3. All the parts to convert to 12V, including the battery, cost about the same as the big honkin' 6V battery.
If I simply take the wire from the GEN terminal on the regulator, and move it over to the BAT terminal on the regulator, will that effectively bypass the regulator?
I would then transfer the wire from the A terminal on the generator to the BAT terminal on the alternator and use that as my main charging line.
From Bob M's schematics, it looks like it would work. |
| mkirsch
08-01-2012 07:12:38
64.80.110.74
Re: 12V conversion wiring shortcut in reply to mkirsch, 07-31-2012 07:39:04
| Thanks John T. I didn't want to cloud the question with all the pesky details.
Any one-wire alternator: $150
Remanufactured three-wire alternator: $30
I also plan on:
1. Adding a ballast resistor to the coil supply wire.
2. Running a wire and diode from the 12V side of the ballast resistor to the alternator 1 terminal for excite.
3. Connecting the alternator BAT terminal to the alternator 2 terminal.
4. Reversing the connections on the coil.
5. Converting to - ground. |
| John T
07-31-2012 08:34:48
216.249.82.117
| | If I simply take the wire from the GEN terminal on the regulator, and move it over to the BAT terminal on the regulator, will that effectively bypass the regulator? YES that by passes the Cutout Relay portion of the Voltage Regulator (its between BAT and GEN). If you do that the hot ungrounded battery feed via the ammeter which is present on the BAT terminal, is then connected to whatever you then connect that terminal to, such as say the output of an alternator........... DONT FORGET MOST ALTERNATORS ARE FOR NEG GROUND so if the tractor were at Pos Ground??? you would have to swap ammeter leads or it will register bass ackwards If a tractor has a coil ignition and you changed polarity, the coil leads would also need swapped HOWEVER if youre already at neg ground (like on most 12 volt tractors) neither of the above swaps are necessary John T |
| Phil Tibbetts
07-31-2012 08:25:44
208.93.14.38
| One more thing don't forget the ballast resistor between ignition wire and coil. |
| MCOHIO
07-31-2012 08:23:36
71.72.158.81
| A properly working 12 volt generator will put out well over 12 volts during operation. I have had a few that tested 19 volts. You need the regulator to keep from over charging your battery. |
| Phil Tibbetts
07-31-2012 08:23:04
208.93.14.38
| Spring for a single wire alternator and all you need is a wire from the alternator to battery nothing in between. then replace your amp meter with a volt meter. I like the volt meter better than the amp meter. IMO |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
