Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Which is which?
[Return to Forum]
AF 70
07-30-2012 14:48:18
66.142.212.55
Working on the electrical of the H. Someone's painted the generator, looks like maybe a couple of times. Can't tell which terminal is armature and which is field. Has original pos ground 6 v gen. Can anyone tell me which is which? Which is closer to engine when it's mounted?
Thanks a lot!!
[Reply]   [No Email]
Owen Aaland
07-31-2012 15:02:51
216.47.35.172
Re: Which is which? in reply to AF 70, 07-30-2012 14:48:18
With a field wire connected to both the light switch and the cutout the low charge circuit will have a high charging rate than using just the light switch alone. The high charge rate will not be affected. Unless the battery is being overcharged there is no problem leaving it as it is.
  [Reply]  [No Email]
Janicholson
07-30-2012 16:12:30
96.24.99.126
Take the wires off, Use a hot wire to brush each terminal the one that sparks a lot is Arm. Repolarize when connected. (I think it is the one close to the engine) Jim
  [Reply]  [No Email]
Patrick HMD
07-30-2012 17:11:05
75.0.246.100
Re: Which is which? in reply to Janicholson, 07-30-2012 16:12:30
Sorry for the image size. That's the best I could do. Well anyway, notice where I scraped the paint off next to the terminal. It's got a very faint "F" stamped on it. That BTW, what you see is a 6 volt gen. HTH.
Patrick
This post was edited by Patrick HMD at 17:17:10 07/30/12.
  [Reply]  [No Email]
Janicholson
07-30-2012 17:27:10
96.24.99.126
Re: Which is which? in reply to Patrick HMD, 07-30-2012 17:11:05
The device on top of it is a cutout relay, not a regulator. It is also wired (from what I see) wrong. If it was originally on a tractor with no headlights from the factory, the field wire should be connected to Field on the cutout. and no other wire connected to Field terminals. If it has lights, and a 4 position light switch, the Field wire connection to the cutout should be removed. The other wire should be 10 gauge, and if it is the arm or Gen terminal it should be attached to the A terminal on the Gen. The other terminal (bat) on the Cutout should be attached to the amp gauge load side. Jim
  [Reply]  [No Email]
Patrick HMD
07-30-2012 19:35:16
75.16.96.97
Re: Which is which? in reply to Janicholson, 07-30-2012 17:27:10
Thanks for bringing that up Jim. I too noticed the wiring not being like Bob's diagrams, and was a bit perplexed, and was gong to start another tread concerning this. But now I see not nesecceary. The doggone tractor runs fine as is. Here's another shot.
  [Reply]  [No Email]
gene bender
07-30-2012 19:07:48
67.55.226.123
They came from the factory with a wire to the field terminals. Ive got several that way and they work. Even runacross some originals wired that way and now you people say they should not be connected. Ive been around long enough to recognize original wiring and have installed gens that have been rebuilt localy and they always have the wire connected to both fields and they work. Do you have a tractor that still has the original wiring
  [Reply]  [No Email]
Nebraska Cowman
07-30-2012 15:22:25
166.182.3.33
Yeah, scratch around, you should find an "F" or an "A". If it's still hooked up the heavier wire is the armature.
  [Reply]  [No Email]
CNKS
07-30-2012 14:53:24
216.144.104.128
Too lazy to go look. The terminals are marked, you may have to remove some paint.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
