| Farmall & IHC Tractors Discussion Forum |
Topic: Ball Hone
[Return to Forum]
| Author |
[Modern View]
| equeen
07-29-2012 00:08:41
209.102.248.236
Okay, I've just read of a "ball hone" and have read a bit about 'em on the web. Sounds interesting. Replaces the spring tension 3 legged honing tool? What's the scoop and how to use without too much wear on walls? Am I really that far behind the times? |
| equeen
07-29-2012 18:10:54
209.102.248.236
Re: Ball Hone in reply to equeen, 07-29-2012 00:08:41
| | Good or bad, right or wrong, my purpose of using the 3 prong hone on the Cub cylinders last year was merely to clean off the light rust. A few passes up and down the cylinders and they were bright and shiny. The engine rebuild shop would have done what, if anything else, needed to be done to the cylinders. I keep learning this other "stuff" from you folks and my head gets to a-spinning. But, it's still attached; so keep on a-teachin'. Thanks. I don't know
| pete 23
07-29-2012 16:23:44
74.32.238.2
| Ball hones are fine. They are never used to straighten or increase bore size to correct piston clearance. They are used to establish that final plateau honed finish to a new cyl, or put a nice cross hatch on a slightly worn cyl. Those three legged flex hones are the ones you want to throw away. Use a good rigid hone to size or correct uneveness of cylinder. |
| george md
07-29-2012 16:09:46
209.213.167.201
| equeen, Jim in the post below explained it well. But in laymans terms what he said was that a ball hone is a step below a spring loaded hone which is junk. If you are going to the trouble to hone a cyl,at least use a sunnen or hall none as they will correct the out of round and taper . george |
| sflem849
07-29-2012 16:39:35
69.197.84.39
Re: Ball Hone in reply to george md, 07-29-2012 16:09:46
| Quoting Removed, click Modern View to see
I didn't read it like that. I read the post to say that every hone has it's place. From what I have seen, some machine shops are using a ball hone to put a cross hatch on. |
| old
07-29-2012 09:26:25
209.86.226.32
| I never have and never will use the ball type hone. I have 2 or 3 of the stone type and have used them for 40 plus years so guess some times you get set in your ways. If you plan to reuse the sleeves you need a ridge reamer no matter what. By the way I just looked on the shelf and low and behold there is a piston and rod laying there from one of the 3 engines I used to build the BA |
| Janicholson
07-29-2012 05:56:19
96.24.99.126
| Four types of hone: Machine controlled Honing (Pro rebuilders) Sunnen Brand style straight hone center pivot hard abrasive hone Ball Hone The pro rebuilders use Machines that drive the hard abrasive stone axially through the cylinder in alignment with the boring bar that was used to resize that bore. (jasper engine rebuilders and many others use that machine shop floor model tool. The Straight hone is a parallel actuated honing system that can make a cylilnder correctly cylindrical and straight, but follows the axis of the cylinder as found (floats in the cylinder) It is best in all ways for surfacing a bore that needs to be sized to a piston after machining. The center pivoted stone based hones, and the ball hones are not ever used (correctly) to change straightness, or roundness, or axial alignment. Both are surface finish modifiers for placing a compatible cross hatching on the metal of the cylinder wall. both conform to the existing shape of the hole, and do not correct wear. Both of these should not be used for material removal as they can (and do) make trumpet shaped irregular wear at the ends of thrir travel if attempts are made to use them for sizing. Jim |
| sflem849
07-29-2012 05:29:07
69.197.84.39
| Go to YouTube. There are a ton of videos showing you how to use one. |
| equeen
07-29-2012 13:42:44
209.102.248.236
Re: Ball Hone in reply to sflem849, 07-29-2012 05:29:07
| Thanks, sflem, for your reference to YouTube. I had never gone there to search for a video. Now, I've tried it and it's great. Now, I can see videos there without someone having to provide a link. |
| sflem849
07-29-2012 15:44:07
69.197.84.39
Re: Ball Hone in reply to equeen, 07-29-2012 13:42:44
I have found it pretty helpful in the past. Remember, just because it is on YouTube doesn't mean it is the correct method! (Same goes for YT for that matter) If I remember correctly one of the ball hone mfgs has a how to video and I would take their word with a lot of confidence. |
| rustred
07-29-2012 05:02:08
184.151.222.186
| no it dont replace the ridged hone. they have been around forever also. they are used for the final piston to wall clearance. first boring , then ridged use, then use ball hone. it is to produse a smoother surface for easier break in. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
