| Farmall & IHC Tractors Discussion Forum |
Topic: 400, W400 or W450
[Return to Forum]
| Author |
[Modern View]
| Brad in WI
07-26-2012 20:57:11
63.135.156.59
How do you tell the difference between the 3 models listed above? A friend has two tractors that he thinks is a standard tread 400 gas (serial # 538) and a W400 gas (serial # 3591). We are trying to find any differences that are obvious cause the sheetmetal is different between the two and both serial number plates are well worn off. The 400 has an engine casting code of "A" and the W400 has an engine casting code of "B", however by looking at serial number breaks we are wondering if it is a late W400 with alot of W450 parts on it. We would appreciate any help at all. Thanks |
| mkirsch
07-27-2012 05:18:38
64.80.110.75
Re: 400, W400 or W450 in reply to Brad in WI, 07-26-2012 20:57:11
| Both the "400 standard tread" and "W400" are the exact same model tractor. Both are "W400" if you could read your serial tags.
You have an early model and a late model.
There were quite a few changes made to the W400 between the 1956 and 1957 model years. The stuff I know about:
The "W" was added to the hood on the later models.
Completely different fenders on the later models.
Dust shields in front of the pedals on the later models.
Basically, you've got a complete set there. |
| ihredo4
07-27-2012 01:47:25
216.73.228.99
| First thing would be a picture. That would help out significantly. When you say 400 do you mean Farmall 400 or the first six month production of the International 400 which was a PRE-"W" designated tractor? SOmewhere mid production of the W-400 they switched the operators platform from basically an open to closed platform. The open platform would be the same as the Super W6-TA. They are basically the same tractor with a tin change anyhow. The late production W-400 has a dust shield that went from the fender to the cowl/hood tin. The fender also changed from the early style to the "flat-top" fender. Basically these fenders extended up and about half way over the top of the tire. As for the W-450 i have not done any research on them so can't help you other than the date codes. Check the codes located on each axle housing, rear end, engine block and any other place you can locate them. The International 400 and W-400 were introduced in 54 with a Z code and then on into 55 with an A code. 56=B, 57=C. The date code looks like 7 24 A which translates into July(7) 24th 55(A). Hope this helps you some. |
| Hugh McKinney
07-27-2012 05:56:25
75.106.0.53
Re: 400, W400 or W450 in reply to ihredo4, 07-27-2012 01:47:25
| My 450 has a code on the left rear axle of 2 12 D. Does that mean that it was cast in February of 1958? Thanks. |
| Andrew Z
07-27-2012 06:55:10
64.252.133.36
Re: 400, W400 or W450 in reply to Hugh McKinney, 07-27-2012 05:56:25
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
